Using 'B' Mode
Discussion in 'Gen 2 Prius Main Forum' started by Marvinh, Oct 27, 2007.
  1. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    I'm wondering. Has anyone tried starting off in 'B' mode in snow? I'm thinking 'B' mode might avoid some wheel slippage because it holds back some torque? Similar to starting off in 2nd gear with convention cars?
    Any thoughts? Thanks! Marvin
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    It doesn't hold back any torque; driving forward in "B" or "D" is
    exactly the same. The behavior difference comes when you let your
    foot up; see this for details. If you like the feel of the car
    "falling on its face" with stronger drag at zero go-pedal in the
    snow, then by all means use it. Downside is that the engine will
    continue to run, even if it's just got to idle, until you move back
    to "D". When you're negotiating slippery stuff and want generally
    quicker response, though, you might find it valuable.
    To avoid wheelspin, just be gentle on the pedal. Search the forums
    for "traction control" to find a litany of sob-stories about it.
    _H*
  3. Neicy
    Neicy Member
    834
    Wakefield, MA.
    I did exactly that last year when I first got my car in Feb. It worked very well. There are certain roads I drive when going to and from work where I need to stop in an incline. If it has been snowing for awhile, but the streets have not been sanded, I find "B" useful since I barely have to touch the brakes to come to a stop.
    Now that I have more experience with how this car handles, I probably will find less need for it this year.
  4. Bohous
    Bohous New Member
    316
    Boston-ish
    I haven't used it to avoid wheel slipping but I use it going down even small hills to avoid using the brakes. I'm not sure if it makes any difference with the Prius brakes but I've always down shifted with previous cars so I still do it.
  5. qbee42
    3,079
    B mode does nothing to avoid wheel spin. As for not needing to use the brakes, B mode does its braking through the front wheels, just as regen braking does. There is no inherent advantage to braking with B mode in slippery conditions, other than a placebo effect. The only use for B mode is burning off excess energy on long or very steep hills.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    <div class='quotetop'>QUOTE(Bohous @ Oct 28 2007, 12:43 PM) [snapback]531422[/snapback]</div>
    How is your milage? because you are throwing energy into the air in the form of heat rather than storing it in the battery to use later. light brake aplication, just enough to make the brake lights come on will acelerate regenerative retardation without friction brakes while putting the car in B will make the internal combustion engine(ICE) spin against compression thereby dumping energy as heat from the exhaust and cooling system.
    I use B when my battery is full, the HSD will spin the ICE at that stage anyway but it gives a bit more engine braking to do it manually.
  7. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Press on the brake a bit, while giving it some throttle; this seems to trick the traction control and might give you half a chance of getting moving when it's slippery.
  8. qbee42
    3,079
    <div class='quotetop'>QUOTE(Pinto Girl @ Oct 28 2007, 12:19 AM) [snapback]531448[/snapback]</div>
    Hmmm, interesting idea. I haven't tried that one. I'll give that a try next time we get some snow - should be soon.
    Pinto Girl, do you think this works because the friction brakes add some drag to the drive wheels? That would be my guess - kind of a poor man's posi-traction.
  9. Bohous
    Bohous New Member
    316
    Boston-ish
    <div class='quotetop'>QUOTE(patsparks @ Oct 27 2007, 11:51 PM) [snapback]531438[/snapback]</div>
    Well, considering the circumstances we are talking about (driving down an icy hill) I don't give much thought to my mileage or pay much attention to my consumption screen. I don't drive around town in "B", I'm just saying that if it's icy and I am descending a hill I feel more comfortable letting the transmission keep me slow and steady rather than my brakes. Like I said in my initial post, I don't even know if it's even beneficial from a safety standpoint. It stems from history of driving cars without ABS and fearing locking up the brakes.
  10. patsparks
    10,664
    567
    <div class='quotetop'>QUOTE(Bohous @ Oct 29 2007, 09:23 AM) [snapback]531716[/snapback]</div>
    I'd let the ABS do it's stuff. I did some training with our patrol cars on soft gravel roads and with the brake pressed hard locking the wheels I could still steer the car easy. I must admit I have never seen snow so take what I say with a grain of salt. If you haven't used ABS before it can be scary due to noises and pedal pulses but it works great. Practice an energency swerve under hard brakes in a gravel carpark with lots of room at about 50km/h to get a feel for it.
  11. qbee42
    3,079
    <div class='quotetop'>QUOTE(Bohous @ Oct 28 2007, 07:53 PM) [snapback]531716[/snapback]</div>
    It's not beneficial from any standpoint. You are coming at this from the standpoint of a normal car and normal transmission, which is leading you astray. With the Prius it's really quiet simple. A non-panic press on the brakes and engine braking (B mode) will produce exactly the same effect at the tires: Both will load the front wheels to slow you down. The only difference is that B mode will throw away some of the energy, while normal braking will recapture as much as possible through regenerative braking. Neither is going to give you better control; neither is better for the brakes; neither is safer. In both cases ABS will kick in if your front wheels start to slide. Save B mode for long or very steep hills, otherwise just step on the brake pedal.
