what happens if you exceed the maximum weight lmit?
Discussion in 'Gen 2 Prius Main Forum' started by busyrosy, Oct 30, 2007.
  1. busyrosy
    busyrosy New Member
    113
    Bay Area, CA
    Hi Folks,
    I am about to venture on a 300 mile drive trip to pick up an old metal cabinet full of lead types (ok, so I do letterpress as a hobby). I'm pretty much inheriting the stuff from an out-of-business printer who wants to get rid of everything asap. The thing is, I have no idea how much this cabinet full of types weighs, and it really depends on how full the drawers are, but I'm estimating that it will weigh anywhere from 500 - 900 lbs.
    Here's my dilemma -
    I'm aware that on the "book" the maximum weight capacity for the prius is 850 lbs. I can't carry the cabinet in and out of the car myself (it will be disassembled to lighter pieces, than re-assembled again - so no problem on that aspect), so I'm bringing my fiance with me.
    He weighs: 215 lbs
    I weigh: 110 lbs
    I'm also taking my dog: 15 lbs
    The cabinet: 500- 900 lbs
    We've cleaned out the car to reduce as much unneeded weight as we can.
    So right now, we're looking at 830 - 1230 lbs of total load. We're planning to take a trip to the gas station to increase our tire air pressure.
    So, what do you think? Advice?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Others have dramatically exceeded that. I think if you take it easy on the accelerations and braking you'll be fine.
  3. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I've found that if you put too much weight in the back, the headlights point off into the trees and the steering goes light, which is not safe. I suggest loading the weight as low and as forward as possible. Maybe you could put some drawers of type on the floor of the rear seat, or even on the floor of the front passenger seat if there's room. Use the area under the rear cargo space, too, though keep in mind you might have to get at the spare tire. Wrapping the drawers in garbage bags will keep your car cleaner, and will help keep all those letters from becoming missiles in the event of an accident. Be very wary of bumps and rough roads, as the suspension will have less travel than usual, and it's easier to damage the underside.
    If you drove up with a bicycle in the back, hubby (sorry, fiance) could ride home and you'd have more room in the car! :)
  4. Godiva
    Godiva AmeriKan Citizen
    10,339
    Did you remove the spare tire? That will save you a little more weight.
    Other than that, I think you'll be fine. But don't drive over any bumps or dips if you can help it. And take it slow.
    I'd make sure I distributed the weight as evenly as I could. Put some on the floor in the back passenger area. Then evenly distribute the rest across the back cargo area. May I assume the back seats will be down?
    Make sure everyone goes "potty" before you leave.
  5. qbee42
    3,079
    Make sure it's sans serif type; that will shave off a few pounds. :D
  6. GeekEV
    GeekEV Member
    417
    NorCal, USA
    I don't have a lot of experience with heavy loads, but I'd take care to make sure your shocks aren't bottoming out causing your wheels to scrape. That would be bad. Maybe rent a trailer and tow-hitch from your local U-Haul joint if it really makes you nervous?
  7. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    <div class='quotetop'>QUOTE(Mr. Zorg @ Oct 30 2007, 10:29 PM) [snapback]532732[/snapback]</div>
    Towing with a Prius is not recommended.
  8. richard schumacher
    7,664
    1,045
    United States
    A trailer would be worse as the manual says no towing, period. Yes, I know people have exceeded the weight limit and towed stuff and not immediately ruined the car. But for pity's sake! Why take an unnecessary risk asking a $23,000 asset to do something it was not designed to do? The best way to avoid trouble is to avoid trouble: spend $150 to rent a U-Haul truck for a day and eliminate all worries.
  9. Neicy
    Neicy Member
    834
    Wakefield, MA.
    You might want to add a couple of extra pounds of pressure to each of the tires, and as hyo silver said try to evenly distribute the weight. Let us know how it goes!
  10. drifty1955
    drifty1955 New Member
    100
    If it was me I'd just rent a big 4 door car. Best $300 you'll spend. Your turning your Prius into a 1/2 + ton pick up. A break down on the road will cost you alot more than $300. Free stuff can sometimes end up costing alot more than there worth.
    OR.....go there..rent a lock up locally there for $ 50...stow half of the stuff...and then bring back a safe portion..go back at the end of the month and bring the rest. In the meantime make sure you have fresh oil in the engine & trans and it will be a fun trip both times. Good luck and don't kill your car.
  11. n8kwx
    n8kwx Member
    236
    Arlington Heights, IL - NW Chicago Suburb
    <div class='quotetop'>QUOTE(okiebutnotfrommuskogee @ Oct 30 2007, 10:39 PM) [snapback]532738[/snapback]</div>
    Neither is loading over the GVWR.
    Both have been done (within reason) without incident.
  12. jk450
    jk450 New Member
    55
    <div class='quotetop'>QUOTE(busyrosy @ Oct 30 2007, 10:34 PM) [snapback]532717[/snapback]</div>
    Do you plan to secure this cabinet so that it will not fly forward in a severe collision? If not, you may want to ask a physicist the effective mass of a 900-pound object at 60 MPH...
    Overloading the vehicle is not your biggest potential problem.
  13. patsparks
    10,664
    567
    Adelaide South Australia
    I would have thought the one off cost of renting a small truck or ute and fuel would be better spent than risking damage to the interior of your Prius or any nice car.
  14. Devil's Advocate
    922
    Las Vegas, Nevada
    First,balance the load,left to right front to back, or get a little trailer.
    Second, modify your driving according to the load. Slower starts (acceleration) and longer stops (deceleration).
    I have hauled a 2,400 load (850 passengers and gear and 1,750 trailer) from Vegas to LA and back no problem. Except for only getting 29 mpg!
  15. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    If the equipment ways over 1000lbs forget it and rent something that is safe to do it.
    Car makers routinely put very low limits on vehicles. On the Honda element we have the weight limit is a very low 850lbs INCLUDING PASSENGERS! With four big people you are over that limit without ANY cargo. On a two mile trip we moved around 2000lbs of bricks. We never went over 30mph. The back of the element dipped down but the tires seem to have little problem. On a trip as long as yours you need to worry about tire damage and heating as well as a host of other problems like wearing the driveline on hills.
  16. sub3marathonman
    sub3marathonman Active Member
    557
    75
    I think you could be in for this: http://www.swapmeetdave.com/Humor/Workshop/Overload.htm
    Why not just have the 215lb fiance drive another car or light pickup truck?
    First of all, you're not even sure how much this stuff weighs. Second, of the 850 lbs the Prius can carry, you're using up 340 pounds with humans and a dog.
    At 110 lbs you are a very efficient human and could go alone and get somebody there to help load the Prius. And you can bring the dog if you need some company, Fido weighs a lot less. :D
  17. busyrosy
    busyrosy New Member
    113
    Bay Area, CA
    Thank you folks :) We made the trip, and I'm pleased to report that we still got over 50 mpg on our way back with the load. We drove all the way on 101, which meant that we were driving at a very good speed 45 - 60 mph most of the way with very little traffic. The toughest hurdle was the speed bumps at our residential streets when we reached home, but we drove over those very slowly. Oh and the second toughest thing was to carry the metal cabinet up the stairs.
    We're thinking about taking another trip and bringing back another one of those cabinets....
