2007 PRIUS WORKSHOP MANUAL ??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FloridaWen, May 11, 2007.
  1. dorf
    dorf Member
    132
    Little Rock
    Just a little info to add to all of the above posts.
    I surveyed all of the 2007 topics and purchased Toyota Vol #1. I thought it would be the best bang for the buck (info) so to speak. I was disappointed with the manual.
    There is allot of dealer checks and routines and gobs of info but not for the average guy just wanting, do it your self info. Hard to find stuff. Difficult to read and understand.
    2007 Vol 1 contains the following subjects. Service Specs, Maintenance, Engine Control Sys, Engine Mechanical, Fuel, Emission Control, Exhaust, Cooling, Lubrication, Ignition, Starting, Hybrid Vehicle Control.
    I'll probably purchase the remaining ones later.
    But there still needs to be Basic Do it Yourself CD or Manual for these cars.
  2. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    Nope, two separate machines. [You think I was about to let any
    windoze box directly touch the intertubes? Heh..] If you poke
    around my web stuff carefully you'll find where I put my generated
    index for the '04 manual, and several rants about it that landed
    there and on PC in the april/may '05 timeframe. It *was* a nightmare
    but in retrospect well worth the time, because it's all good learning
    material and I could then look up just about anything for other
    people on the forums as well as for my own purposes.
    There are some third-party service information companies out there
    geared for auto-tech subscriptions, like Mitchell and Alldata, that
    try to cover *all* makes/models under one roof so show owners don't
    have to subscribe to all the OEM sites themselves. Except that they
    often make a few compromises on completeness. Getting all that stuff
    100% right is hard work, which is why many manufacturers contract
    out a lot of the manual-writing and distribution work.
    _H*
  3. drifty1955
    drifty1955 New Member
    100
    <div class='quotetop'>QUOTE(FloridaWen @ May 14 2007, 10:01 AM) [snapback]441629[/snapback]</div>
    The way your posts read I picture you standing on top of your recliner screaming at the top of your lungs.You write some intense posts.
  4. FloridaWen
    FloridaWen New Member
    573
    Plant City, Florida
    <div class='quotetop'>QUOTE(Drifty'sDad @ Nov 9 2007, 12:34 AM) [snapback]537096[/snapback]</div>
    Oh you have it so wrong.... the recliner is old and very unstable and will tip over if I stood on it. I use a wooden soap box and a megaphone (accoustically amplifies the screaming) !! :D
    I think it may also have something to do with the Florida "mold"..... particles have invaded my brain !!
    [attachmentid=12395]
  5. dogfriend
    7,512
    1,191
    Carmichael, CA
    Yep, that's pretty much how I pictured it. Except I thought you might be slightly taller. :lol:
