Maintenance issues with 1st generation Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by paulccullen, Nov 6, 2007.
  1. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    A friend is looking at purchasing a used 1st generation Prius, and is asking me what maintenance/repair issues to expect.
    Does anyone have any ideas? I tried searching here without much luck.
    All I could think of was potential battery replacement. I'm thinking that many 1st gen Prii must be approaching that. Do we have any idea of the average battery life before replacement, and the replacement cost? (maybe 150K miles?)
    Thanks!
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(paulccullen @ Nov 6 2007, 08:19 AM) [snapback]535520[/snapback]</div>
    just get the dealer to run the serial number and make sure that all the TSB and service bulletins are up to date. Steering box issue, HC absorber Cat sticking valve, and the HV battery sealing are up to date. The throttle sensor has been an issue but there is a member servicing them. Rusty rotors have also been an issue. Other than that just normal wear and tear issues, struts, tie rod ends, that sort of thing.
  3. jk450
    jk450 New Member
    55
    How many miles on the car, and what year is it?
  4. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    No quantifiable data, but it seems I've seen more reports of transaxle failures than battery failures in the NHW11 (i.e., 2001-2003) Prius. The Prius Technical Stuff group on Yahoo has had some discussions on transaxle problems. You might check that out.
  5. bwilson4web
    16,337
    <div class='quotetop'>QUOTE(paulccullen @ Nov 6 2007, 10:19 AM) [snapback]535520[/snapback]</div>
    The battery replacements have been too sparse to draw any conclusions. Regardless, everyone else has hit the biggies.
    Perhaps your friend might come here and ask their questions directly?
  6. paulccullen
    276
    Seattle, WA
    <div class='quotetop'>QUOTE(bwilson4web @ Nov 6 2007, 02:26 PM) [snapback]535761[/snapback]</div>
    Thanks Bob et al, I'm emailing him a link to this thread with everyone's feedback...
