Yellow icon on top right corner of MFD
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AnailizeR, Nov 8, 2007.
  1. AnailizeR
    AnailizeR Junior Member
    57
    US - Somewhere....
    So i was driving "my love" down the parkway mind my own business a bit pissed off with the cold weather and the loss of 5 MPG on my trip to work ... :) when I looked at my MFD and i saw this yellow square on the top right corner of the screen ... there wasnt anything else no warming lights on the front console or anything ... so i dont know what it was .. does anyone know what it was?... because that one kinda got me worried ... I dont want "my love" to die .... :( by the way "my love" is a 2007 Prius base model :)
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Did it blink and go away shortly thereafter? Was it a copy of the
    "snowflake" icon? You didn't include a picture...
    _H*
  3. Tideland Prius
    16,589
    it's the snowflake icon, I'm fairly sure (esp. since you said it was yellow).
    It comes on when the temp drops below 37°F
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(Anai @ Nov 8 2007, 06:55 PM) [snapback]536924[/snapback]</div>
    I agree. At 34F a warning will flash on the MFD for a second or two. One needs to be looking at the MFD when the temp changes to 34F to notice. The good news is that this silly icon isn't on the dash as in prior years.
    It's time to block the grill. "Frost on the car. Frost King in the grill." Blocking the grill will keep the ICE warmer longer. After I blocked my grill my winter mpg didn't drop. Also check your tp. Lower tp decreases mpg.
  5. qbee42
    3,079
    <div class='quotetop'>QUOTE(JimN @ Nov 8 2007, 09:18 PM) [snapback]537007[/snapback]</div>
    Mine shows at 37°F. It's always nice to know when it turns 37°F. :rolleyes:
  6. AnailizeR
    57
    US - Somewhere....
    Thanx guys .. it was the snowflake ... I was driving back from work and it popped up again .. and I notice that the temp was 36F so when I got home .. I took my ac which was in the garage placed a 3in flex pipe in front of it and turned it on .. in front of the car where that funny lonely sensor is at and wouldnt u know it .. once it got to 36F on the ac .. my bro saw the light pop up again .. :) and it looked like a snowflake.. :) "my love" is alright after all
    Now .. just a question there guys .. how do I "block" my grill? Sounds silly to me but if it improves mpg i am all for it .. :)
  7. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    <div class='quotetop'>QUOTE(Anai @ Nov 9 2007, 08:07 AM) [snapback]537192[/snapback]</div>
    Different people use different methods. Check out this thread for some really good information: http://priuschat.com/index.php?showtopic=27547
  8. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    <div class='quotetop'>QUOTE(Anai @ Nov 9 2007, 09:07 AM) [snapback]537192[/snapback]</div>
    It depends on the expected amount of snow fall in your area. Usually four short pieces of a 2x4, 4x4, or 6x6 will do-- the more snow, the larger the piece. Have one person lift one end of the grill (removing the propane tank first will make it a bit lighter), while the second person slips the pieces of wood under the wheels/legs. Repeat on the other side of the grill. Therefore, if you are in an area that receives a moderate amount of snow and you used the 4" blocks, you can be standing on 4" of packed snow and the grill will still be at the height you are used to in the heat of summer. That, my friend, is how to block your grill. For additional instructions you can try this link--
    http://priuschat.com/index.php?showtopic=39790&hl=grill
    PA P
  9. qbee42
    3,079
    I look for a properly sized pedestrian, and try to time it right at a crossing. :D
  10. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(PA Prius @ Nov 9 2007, 08:33 AM) [snapback]537205[/snapback]</div>
    LOL :)
  11. AnailizeR
    57
    US - Somewhere....
    Funny little PA man ...
