My Prius has developed a very annoying rattle
Discussion in 'Gen 2 Prius Main Forum' started by jc1745, Nov 9, 2007.
  1. jc1745
    jc1745 New Member
    I have a 2005 Prius which I completely love, but unfortunately over the last year or two it's developed an extremely annoying rattle. This rattle appears to be coming from someplace under the small pane of glass that's located between the windshield and the driver's side front window. I don't hear it if the car is stationary or moving at freeway speeds, or if the weather is hot (and, I assume, whatever causes this rattle has expanded a bit and is not able to move).
    Generally, it's loudest when the car is traveling on city streets at about 20 to 35 miles an hour when the weather is cool or cold.
    If you'd had a similar problem, could you please let me know and suggest a way to fix it?
    Thanks!
  2. mhawkin1
    mhawkin1 Matt
    102
    Indianapolis
    How many miles are currently on your Prius?
  3. fairclge
    fairclge Member
    151
    Virginia Beach
    Watch out because sounds seem to reflect off the windshield that come from different areas in the car.
  4. jc1745
    jc1745 New Member
    <div class='quotetop'>QUOTE(mhawkin1 @ Nov 9 2007, 11:29 AM) [snapback]537267[/snapback]</div>
    20,950 or thereabouts.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Check the upper glove box shelf and make sure it is properly installed in the slots and tabs.
  6. jc1745
    jc1745 New Member
    <div class='quotetop'>QUOTE(firepa63 @ Nov 9 2007, 01:39 PM) [snapback]537357[/snapback]</div>
    But the noise is coming from the other side of the car ...
  7. wjtracy
    wjtracy Senior Member
    11,372
    3,609
    Northern VA (NoVA)
    <div class='quotetop'>QUOTE(jc1745 @ Nov 9 2007, 11:06 AM) [snapback]537256[/snapback]</div>
    I've also been noticing a rumble during bumps from that area (2006@23k miles). Not too bad so far.
  8. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    <div class='quotetop'>QUOTE(jc1745 @ Nov 9 2007, 04:46 PM) [snapback]537421[/snapback]</div>
    I'd still check it. The shape of the interior makes finding rattles very hard.
    Ours rattles like an old Chevy.
  9. YoDaddyAlex
    YoDaddyAlex Member
    271
    sound waves can bounce around and make you think it's coming from one side when it is the other.
  10. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    We have repaired several dash rattles at the shop I work at. Try placing your hand flat on the dash just in front of the dash display and press up and down a few times. If you hear a "plastic on plastic" rubbing sound, of you hear a rattle by lightly slapping that same spot, the most likely cause is either the combination meter needs some foam tape added or the defroster vent may be loose. Again, adding foam tape can usually eliminate the noise.
    If you are no longer under warranty, the repair is still rather simple. Most of the dash pieces are "snap together" with the addition of several philips head screws, a couple of 10 mm bolts and the two 12 mm bolts holding the passenger airbag in place.
    Rattling sounds from the corners of the dash area may also be loose a/c duct work. Removing the upper half of the dash exposes the ducts and can allow easy access for adding insulating foam.
  11. christet
    christet New Member
    We just brought our 2007 in for a rattle coming from passenger side area. The dealership where we bought it new replaced the front passenger seat. It was found to have a rattle in the back rest some where. Maybe yours is coming from the same area on the drivers side. We noticed it more on side roads then on freeways.
  12. snowdog650
    snowdog650 Member
    171
    29
    Sacramento, CA
    <div class='quotetop'>QUOTE(SW03ES @ Nov 9 2007, 07:40 PM) [snapback]537571[/snapback]</div>
    Mine, too. My previous car ... a VW GTI ... was *supposedly* notorious for rattles and noises from the interior ... at least according to 90% of respondants over at VWVortex.com.
    Compared to my Prius, the GTI was a fricking vault.
    I am very disappointed in the poor quality of the interior materials.
    Oh, well ... still love the car.
  13. NoMoShocks
    1,292
    83
    Camas, WA
    If you can find a not too busy streach of road where you can match the speed for the rattle, get it rattling and then reach over and press on the interior covering of the window pillres, window glass, dash parts, etc. or have an assistant doing this, you may find it, but I agree, the acoustics of the car are such that the direction from which the sound is coming my fool you. I have hear noises that sound like they are up in the head liner, and then traced them to an empty soda can in the cup holders.
  14. samoan_ridah
    samoan_ridah New Member
    Mine "farts" when I push down on the brake pedal. The noise seems to come from the wheel wells. I've learned to just hit the brakes lightly and not push down too hard at a complete stop.
  15. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    I traced a rattle I swore was coming from the passenger door, to my Maui's in the overhead sunglasses holder!
    And a dash rattel to the center speaker connector I had disconnected months earlier.
    Can't blame Toyota for those. So overall she's been a tight ship.
  16. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    From your description, it sounds like the rattle may be coming from the small plastic triangular panel, which can be popped out very easily for inspection. Take a small butter knife and pry it out. Good luck.
    <div class='quotetop'>QUOTE(jc1745 @ Nov 9 2007, 10:06 AM) [snapback]537256[/snapback]</div>
  17. KTPhil
    KTPhil Active Member
    1,379
    22
    <div class='quotetop'>QUOTE(zenMachine @ Nov 14 2007, 10:26 PM) [snapback]539830[/snapback]</div>
    Mine has had this rattle every winter. It's easy to confirm it--just hold it down and the noise stops. Goes away in summer, as the plastic is more flexible (and probably expands). One of these days I'll remove those panels (where the little vent is) and put some thin foam tape or thin foam packing sheet material under it to stop the rattle.
  18. personallyuneek
    personallyuneek Yankee fan in New England
    47
    NorthEast
    <div class='quotetop'>QUOTE(samoan_ridah @ Nov 14 2007, 06:25 PM) [snapback]539699[/snapback]</div>
    There is a thread on the TSB Forum about the Flatulent Brakes
    http://priuschat.com/index.php?s=&show...st&p=530511
  19. wjtracy
    11,372
    3,609
    Northern VA (NoVA)
    I found my rumble rattle: it is the small plastic dashboard piece you see when you look into the small front side window - drivers side. It is not totally tight and so it rattles a little.
  20. designerprius
    designerprius Junior Member
    Looking through other posts it seems several other people have the same passenger seat rattle that I have. I also a rattle in the middle of the dash - and when i put my hand down on it, it stops.
    It has been pretty cold in toronto, so hopefully the warmer weather will help - if not, it sounds like i can get the dealer to take the dashboard off and install some foam tape.
    The car is so quiet, these minor rattles sound so loud and are so annoying. I've had the car for just over a week. I'm coming from a 2006 3 series BMW and the Prius does not yet compare to the quality of the BMW interior. Funny, cause the Prius payment is $100 more a month than I paid for the BMW!
