Does your car move forward when the ICE cranks?
Discussion in 'Gen 2 Prius Main Forum' started by terryonmac, Nov 16, 2007.
  1. terryonmac
    terryonmac New Member
    I was installing my new Scangauge II and had the power on and in park when the ICE started and I felt the car try to move forward. This is the second time I have noticed this. Is this normal? It is a 2008 model.
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Yeah sometimes it does this. Not sure if it actually tries to move or it's just the give in the engine mounts or something like that?
  3. Neicy
    Neicy Member
    834
    Wakefield, MA.
    It doesn't really move, but it feels like it does. Once you understand how the Prius transmission is set up you will understand what's actually going on when the ICE starts - and stops - especially when cold and/or new. Mine always does that little rock when starting up, and I'm now used to it. Here's one thread, but if you search for shake, shutter, stutter or something similar you will find several threads.
    http://priuschat.com/index.php?showtopic=4...hakes+at+a+stop
  4. hoop
    hoop On The South Texas Coast
    69
    middle of south Texas coast
    <div class='quotetop'>QUOTE(paprius4030 @ Nov 16 2007, 07:25 PM) [snapback]540733[/snapback]</div>
    I believe its just the torque caused by the ice starting.
  5. terryonmac
    Ok, torque makes sense. I have felt the shutter at while stopped but I have read about that and ignored it when it happened. I'm thinking about naming it Herbie as it seems to have a life of its own.
  6. paprius4030
    2,077
    296
    York,Pa.
    If you name it Herbie don't forget to paint 53 on the side of it LOL, At least i think that's the number :unsure:
  7. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    its torque reaction of starting the engine.
    but if you manage to get the parking pawl engaged, the torque reaction comes less
  8. daniel
    14,487
    1,519
    Spokane, WA
    The engine of the Prius is never disengaged. At all times if the engine is running, 60% of the torque goes to MG2 and thus to the wheels. If there is anything preventing the car from moving (such as your foot on the brake) then instead of the car moving forward, MG1 will turn backwards. The car can intentionally spin MG1 backwards to prevent the engine from turning the wheels. But it sounds to me as though what's happening is that when the engine starts that torque is getting to the wheels before the car can react to counter-act it.
    Others have reported feeling the same movement. I've never noticed it, though I do feel a bit of a shake sometimes when the engine starts or stops roughly.
  9. Tenebre
    Tenebre Custom User Title
    111
    Stockholm, Kingdom of Sweden
    <div class='quotetop'>QUOTE(daniel @ Nov 17 2007, 02:26 AM) [snapback]540760[/snapback]</div>
    The OP stated that the car was in park.
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Because I always engage the parking brake and don't rely on the parking pawl I never feel this, yes even in the garage. I think it is the car moving until the park pawl engages if it is left on top of a tooth. It's just like an automatic car pulls forward except the Prius has the affect in park (momentarily) when the park brake isn't on.
  11. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(Tenebre @ Nov 22 2007, 07:26 AM) [snapback]542892[/snapback]</div>
    Even in Park, the engine is not disengaged. No component of the drive train is ever disengaged. The parking pawl allows a very small amount of movement, sufficient to feel when the engine starts.
  12. Tenebre
    111
    <div class='quotetop'>QUOTE(daniel @ Nov 22 2007, 07:53 PM) [snapback]542951[/snapback]</div>
    Even if you remove the front wheels, you will still feel the engine start. You are not feeling the car move by means of the engine causing the wheels to turn.
  13. YoungOrganist
    YoungOrganist New Member
    Bahstahn MA
    2002 Prius
    I have the classic, and when I put it in park, it stays put, but as the ICE starts there is a clunk, the shifter jerks, and the car rolls forward and back. weird
  14. Tideland Prius
    16,544
    I would've said no until today.
    In the snow/ice/slush, yeah you can feel it lurch forward when the ICE starts up. Shows you how much more power the engine is putting to the wheels compared to the battery when it's creeping.
