FM Reception sucks
Discussion in 'Gen 2 Prius Audio and Electronics' started by rwithop, Nov 29, 2004.
  1. rwithop
    rwithop New Member
    121
    SF Bay Area, CA
    Is is me or does the FM reception on the 2005 Prius suck?
    I live in the SF Bay Area, and so far my my 10 year old Celica gets better reception than my new Prius. Anybody else having this problem?
    Ryan
  2. GeoffM
    GeoffM Junior Member
    Long Island, NY
    Yes, it sucks. I solved that problem by installing XM, but you're right, it should be much better, especially considering this (mine at least) is the "premium" sound system.
    Geoff
  3. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    are you sure its the FM or the speakers?
  4. prius04
    prius04 New Member
    1,161
    NorthEast USA
    I've got the 2004 and I'm under the impression it's the same car.
    But my reception is about the best of any car I've owned recently. I used to listen to 2 stations because I drive about 25 miles to work and I used to have to change stations all the time. One station closer to work, the other closer to my home. Now I can usually stick with one.
    So the radio must not be the same.
  5. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Both FM and AM Reception seem great to me.
  6. flareak
    1,016
    St Louis, MO
    i wonder which of you has which package. some people report the center speaker is crapola
  7. prius04
    prius04 New Member
    1,161
    NorthEast USA
    I've got package 9 which is supposed to be like the 2005 package C. It's got the 9 speaker system.
    The current system is a JBL. When I go home tonight I'll see if mine is also the JBL.
    Who knows, maybe it will turn out that your antenna is not hooked up or something like that.
  8. rwithop
    rwithop New Member
    121
    SF Bay Area, CA
    No, its not the speakers. CD sounds great. Some stations sound good.
    I don't have the premium sound package, just the basic.
    Perhaps my tweeters weren't as good before, but now I hear quite a bit more static on the same stations I could hear just fine in a 1994 Toyota.
    For those of you that went XM, which product did you choose and how did you hook up the power?
    Ryan
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    My FM is fine except when nearby taller buildings are between me and the tower.
