Navigaton Arrow Orientation - can I change?
Discussion in 'Gen 2 Prius Audio and Electronics' started by powereli, Nov 20, 2007.
  1. powereli
    powereli New Member
    Burlington, VT!
    Does anyone know if there is a setting to make it my navigation arrow always points 'up' on my screen?
    The default setting is that north is always 'up' on the screen, but I want to switch it.
    Thanks in advance!
  2. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    Sure. Just press the little compass in the top left corner of the screen.
  3. Sarge
    Sarge Senior Member
    1,325
    784
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    You can also use the voice commands "North Up" or "Heading Up" to toggle this setting.
  4. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    You've really got to wonder why North Up is the default, I'll bet that most folks want the direction that they are heading up.
  5. qbee42
    3,079
    <div class='quotetop'>QUOTE(dhancock @ Nov 20 2007, 07:54 PM) [snapback]542210[/snapback]</div>
    It's conventional on chart-plotting navigation systems. It comes from the map standard of having north up.
  6. powereli
    powereli New Member
    Burlington, VT!
    on my rig, the North Up setting is NOT the default.
    Thanks for all the help!
