Prius Lighting
Discussion in 'Gen 2 Prius Technical Discussion' started by Spinnerbug, Dec 2, 2007.
  1. Spinnerbug
    Spinnerbug New Member
    28
    Lincoln University, PA
    I am about to be a new 08 Pkg 6 Prius owner, probably next week when I am told it will arrive. One question I have ....are the lights all LED bulbs or otherwise. I was not sure when looking at thru the lenses, but would assume they are. I know what happens when one assumes, so I thought I would ask the experts. Are the dash lights etc. LED? Can't wait to get the car. :)
  2. hv74656
    hv74656 Member
    145
    Morro Bay, CA
    Unless Toyota changed them for the '08, all of the interior lights are incandescent bulbs. There is one orange LED in the lower glovebox and the brake lights are also red LEDs.
    If you're up to changing them out yourself, there are LEDs on ebay that will fit the interior fixtures in the Prius. There are also LEDs available for the exterior lights, but many have noted that they are not bright enough for practical use.
    For more information on LEDs and the Prius, visit your local library or Darell's page below.
    http://www.evnut.com/prius_mods.htm
  3. Spinnerbug
    28
    Lighting
    Thanks for the information. I was hoping that at least the brake lights were LED...Do you know if the front amber turn or running lights are LED or incandescent?
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    86
    All of the running lights except the brake lights are incandescent. If you have HID headlamps, they are not incandescent either.
