10,000 - 1 year check up... any tips
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by icharry, Dec 3, 2007.
  1. icharry
    icharry Junior Member
    27
    Los Angeles
    Ok, so I am going in for my 10,000 mile service tomorrow... any tips? I'll try and read the boards tonight. but soooo many things to do (kids gifts shopping wrapping, vacation planning... Oh and work).
    So I know to ask for 3/4 full on the oil? right?
    42/40 air in tires?
    Any other stuff to ask for... or tell them not to do?
    Thanks
  2. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Don't ask for their generic 10,000 mile maintenance, else you could end up paying for items Toyota doesn't recommend for the Prius. Instead, show them the Prius maintenance schedule and tell them you want that and nothing more.
    Not sure if I'd ask for 3/4 full on the oil; that might put it a little low. I would tell them 3 and 1/2 quarts and no more. Then check the level before you leave to make sure it's not overfilled.
    What your inflation pressure is is your preference (realizing that higher pressure = better fuel economy), but they might drop the pressure down if you have it higher than the minimum. If the pressure is where you want it, tell them to leave it alone.
  3. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    10k according to the maintenance schedule is not a big deal. Not much more than an oil change and tire rotation. Don't sweat it! If you use synthetic oil, they're likely to fill from plastic containers, so you can ask for 3-1/2 in the car, and 1/2 container in the front seat. The Toyota dealer I've been to was happy to do that for me.
  4. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    Be very careful as most Toyota Service Dept. want to sell you way more than you need. When I did my 10k service they had this very long involved looking list up on the wall for the low price of $349.00 plus tax. Once I read the list all that I need was an oil and filter change and a tire rotation and that is according to the scheduled maintenance manual that comes with the car. They gave me the hard sell but I wouldn't budge. You shouldn't either.
  5. icharry
    27
    Los Angeles
    thanks... i'll stand firm for just oil & tires...
  6. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I discovered this by accident;
    Before going to the dealer, take out and clean your engine air filter and especially you in cabin air filter behind the glove compartment. By clean I mean just run the vacuum cleaner over it so it looks good as new.
    When the dealer calls and states that your in cabin (or air conditioner) air filter is dirty and needs replacing, you have discovered a dealer that needs replacing and you now have a good idea of the quality of their 3000 point inspections.
  7. yocuteem
    yocuteem New Member
    maintenance
    I've had my Prius since June 06 and do all of the maintenance myself (oil change, tire rotation, air filter changing, etc). I also have a Toyota Sienna and my ex-dealer really pulled one on my wife when she took the Sienna in for an oil change. The car had 20k miles on it and they said that it needed the fuel injectors cleaned and two new run flat tires on it. She's not car savvy and just thought that it was needed so she told them to go ahead. The fuel injector cleaning was about $70 and the tires were $249 each. So, yeah the bill was rather high. When she called me I told her to get the old tires from them and bring them home so that I can inspect them. But, somehow they "misplaced them". So, there are scum bag car dealers out there...
  8. icharry
    27
    Los Angeles
    Well, No. Hollywood Toyota was fast and easy. I pulled in 30 minutes after they opened, no appointment, told them I was due for a 10,000 mile service. They did not try to add anything to the service - just oil & tires. I asked about the 3/4 oil - he said no problem (I checked and it was spot on), same with tire pressure.
    My local JiffyLube is $35 bucks (but they do not rotate the tires). I paid $79, and was on my way about 70 minutes later. Quick and easy.
  9. TimMan
    TimMan AC or Bust
    44
    Bucks Cty, PA
    Price for the work must vary!
    I had the same thing done in about 35 minutes; its cost me $48.79.
    :eek:
  10. richard schumacher
    7,686
    1,068
    United States
    It's easy: always consult the Scheduled Maintenance Guide and show the correct page to the service writer.
  11. agile pagile
    agile pagile New Member
    46
    Benicia, Ca
    TimMan
    Awesome, what dealer did you use?
  12. TimMan
    TimMan AC or Bust
    44
    Bucks Cty, PA
    PA Toyota dealer
    I used Team Toyota of Langhorne, PA. They have a brand new service center that is open until 9pm M-Sat. Awesome set-up for customer waiting. Also, has a deli, huge TV's, theater seating, separate child play area, etc.
    Tman;)
  13. blamy
    blamy Member
    380
    Central Florida
    If your able to you can do your own rotations with a small floor jack and a 1/2" Torque Wrench and 13/16" socket. That can save you a few bucks every time you go in for scheduled service. You also get the knowledge that it was done correctly. I have found loose lugnuts after a tire rotation.
