EV Factory switch - not working
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ToddWess, Dec 3, 2007.
  1. ToddWess
    ToddWess New Member
    40
    Fairfax, Virginia
    I bought a factory EV Switch from Sigma. The product is exactly as promised, but it didn't work.
    I've double checked my connections. I got a VERY good seating of the pin in the plug behind the glove box, and it lights up when I turn on the headlights.
    But when I turn the car on, I press the button . . . nothing.
    I let the car warm up. Then turn it off . . . turn it back on . . . press the button . . . nothing . . . press it again . . . nothing . . .
    Has anyone had any success with an 08 Prius? Has Toyota blocked this out on this model?
    Thanks,
    Todd
  2. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    When I first installed my switch I had the same trouble. I thought it didn't work either. I took it for a drive and it seemed to work OK. I found out that the EV switch does not work in P (park) or B. You must be in D or R for it to work.
    Hopefully that is all it is.
  3. ToddWess
    ToddWess New Member
    40
    Fairfax, Virginia
    Thanks
    Hey, thanks for that! I'll give that a shot tomorrow morning!
    Todd
  4. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Do you hear any sort of beep when you press the EV button? If it's not beeping, you may not have proper contact somewhere.
  5. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    Huh?? *My* EV switch works fine in park, which in fact is how I
    prevent initial engine startup when needed. Is there something
    peculiar about the cruise-control circuitry that prevents the
    coastal widget from working unless you're driving? That would
    be a total crock if it's true, and yet another reason to just
    put in a direct switch. It seems like the coastal units have been
    dropping like flies this year...
    _H*
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    This is the right answer.
  7. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Is that the right answer? My '06 doesn't beep going into EV mode, but it goes into EV mode nonetheless. The way i can be sure is to put the MFD on a screen OTHER than "energy monitor" and entering EV mode will switch the display to energy monitor.
    Still, you might not have proper contact somewhere. What I did, with hobbit's gracious guidance when installing, was to first insert the ECU pin/wire, and then power up and test by touching the bare end of the ECU wire to grounded metal (rim around the DC outlet, i.e. cigarette lighter if you don't have panels off). That worked, so I knew that the first and most crucial part was in place. Getting the wire routed, the switch in place, and soldering the ECU wire to the harness wire was trivial after that.
  8. efusco
    19,891
    1,196
    Nixa, MO
    It should beep in any screen but the ENERGY screen.
  9. bestmapman
    1,289
    242
    Hobbit, you installed mine, a direct switch. Remember when we first started it up and the engine came on? We didn't know why. Well, ever since then it works as advertised except not in park. Go figure, but that is what it is doing.
  10. Ichabod
    1,794
    Newton, MA
    I was confused by this, so I tested it out this morning. I thought maybe because I have the MFD set to "Beep Off" mode so button beeps aren't there, that EV mode doesn't beep either because of that. But no, it doesn't beep when entering EV mode, but it does beep 3 times when it can't enter EV mode. I guess this is a difference in model year? I think I remember hearing that somewhere around here before too, so I never gave it a second thought.
  11. lcooper
    lcooper New Member
    Coastal EV kit no longer working...
    Hi All,
    I installed the Coastal EV kit a year ago. It worked perfect for about a year and lately it stopped working completely. I did got to Toyota recently for an oil change so I'm wondering if maybe some firmware update disabled it. Or do you all think some loose connections is a more likely scenario (after 1 year)?
    Cheers,
    -Lee
  12. Ichabod
    1,794
    Newton, MA
    I'd bet on the side of "loose connection." I think if there were a "firmware upgrade," 2 things would happen:
    1. Everyone here would know about it.
    2. Your dealer might charge you a large amount to install it, but even if not they'd probably go out of their way to tell you about such a thing being done to your car.
  13. laskint
    laskint New Member
    Northern Virginia
    I just did the light switch EV mod and it goes to the Energy screen when I turn on EV mode. No beeps. I only get 3 beeps when I gas it too much or if I go over 34mph and do not manually turn it off. Perhaps other years had beeps. I wish I had a beep instead of having to watch the screen to change!
  14. lcooper
    lcooper New Member
    Based on some of the posts above - I tried turning my Coastal EV mode "on" after turning the car on and immediately putting it in Drive and it worked. I could have sworn that in the past it worked fine from Park (but now it doesn't). And it's always been 50/50 for me as to whether I got the initial beep or not when putting it into EV. I'll try to run some more experiments and follow up.
  15. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    The coastaletech unit works fine when in motion. Any time the battery reads more than two bars, engine temperature is nominal, and your foot isn't buried in the throttle, it should engage. Otherwise it should beep and complain "Cannot switch to EV mode now."
    ~ dan ~
    The big issue causing failure in the coastaletech module is exactly what I described before - the contact points fatigue due to thermal creep. It's easily remedied by soldering the connections solid or by THOROUGHLY crimping the wire taps in place, which (again) is harder than it looks because of the tight space.
