2005 Prius poor mileage
Discussion in 'Gen 2 Prius Technical Discussion' started by VDIndia, Dec 4, 2007.
  1. VDIndia
    VDIndia New Member
    I bought used 2005 Prius in May. In October I bought brand new Cooper tires, shortly after that the weather changed drastically, I have noticed drop significantly in mileage. It give only 26 mpg. I work only a mile from home. So maybe I am not giving enough time to warm up. Any thoughts?
  2. shankarunni
    shankarunni New Member
    So, what was your mileage before you changed your tires and the onset of Winter? Did you still live 1 mile from work then?
    Given that you only drive 1 mile each way, and then let the car cool down, and then drive 1 mile back, yeah, 26 mpg is not far out of the ordinary. The Prius takes about 10 minutes to "warm up" before achieving peak mileage.
    The best sort of commute for the Prius is a longish (20+ minute) city commute at average speeds of 40-50 mph or so with a few stops thrown in.. (I've achieved short-term mileages of upto 60mpg in conditions like that).
    For Freeway commutes (mostly 65-70mph, 20+ minutes), I get about 46-48 mpg. Anything less than 10 minutes, and your mileage drops dramatically.
  3. ceric
    ceric New Member
    1,114
    Fremont, CA
    I would ride a bike if I were you. 1-mile from home!
  4. Clubford00
    Clubford00 New Member
    93
    Buffalo Grove, Ill.
    i live in Chicago and in the summer i average about 45-48 mpg. In the winter it goes down to about 38. 26 seems a little low but not completly out of the norm.
  5. drees
    drees Senior Member
    1,782
    247
    26mpg sounds about right for a 1 mile commute in the cold.
  6. VDIndia
    VDIndia New Member
    Poor mileage
    It use to be in mid 40s. I live in Montana and I did live one mile from work then.
  7. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    under 30 mpg doesn't surprise me for the first 5 minutes of a cold Prius. Any car will get really crappy mileage during warmup, it's just that the Prius gives you the data.
  8. richard schumacher
    7,664
    1,046
    United States
    Are your tire pressures now too low? Tire pressures should be checked at least monthly, or whenever average outdoor temperature changes by more than about 10'C/20'F.
    For improved fuel economy fanatics run pressures higher than those recommended by Toyota (but *not* greater than the maximum shown on the tire itself). I use 42/40 PSI front/rear.
  9. N3FOL
    N3FOL Member
    891
    Stewartstown, PA.
    1 Mile Ride
    Even with a regular vehicle, I would not even ride a car for just 1 mile. It is really bad for the motor and exhaust system. If you really have to ride due to road conditions and for your safety, the low mpg sounds about right for a very short trip.
  10. danatt
    danatt New Member
    145
    Connecticut
    Agreed. Bike.
    If not - then EV.
    Maybe one of these -
    http://www.zenncars.com/
    Check out the fun video.
  11. patsparks
    10,664
    567
    Adelaide South Australia
    For your personal fitness and reduced fuel consumption I would sugest parking about a mile away from work. I think walking a mile each way to work would help.
  12. wile-e
    wile-e Junior Member
    Have the 12V battery checked. My stock battery was running out of juice and my mileage was tanking. Especially with the colder weather. I put a new Duralast Gold 51R in and watched the mileage move right back up where it should be. Just a thought of what could be going on.
