Rear wheels charge battery?
Discussion in 'Gen 2 Prius Main Forum' started by SunTan, Dec 5, 2007.
  1. SunTan
    SunTan New Member
    This is probably a dumb question:
    The center console "animation" shows when the battery is charged (either by the gasoline engine or front-wheels). I notice the rear wheels are not connected to anything, so my question is, why not use them to charge the battery when the car moves?
    --SunTan :confused:
  2. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    Sounds like a good idea. However, the rear wheels are in fact not connected to anything, so that would require a pretty big modification to hook up something like a generator or motor.
    You could make a suggestion to Toyota to incorporate this idea in the next generation Prius.
  3. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    That's not necessary, they are already planning to offer it.
    The third of the 3 new Prius models is expected to offer AWD... which will have a motor in back, just like Estima & Highlander already do.
  4. Tideland Prius
    16,602
    4WD-i models offer rear wheel regeneration (RXh, HiHy and LSh in NA).
  5. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    The added weight for this would negate the benefits since when you are slowing down the kinetic energy of the car is transfered to the front of the car.
    Now if the car was 4wd, alot of the needed components is already installed, so other than cost there's little reason not to do it.
  6. qbee42
    3,079
    This isn't another perpetual motion thread, is it? I hope you are not suggesting that the rear wheels be used to charge the battery while the front ones are used to power the car. That is a net energy looser.
  7. Vagabond
    1,198
    Southern California
    I don't think that's what he was getting at.
  8. pearsonrj
    pearsonrj Junior Member
    64
    Concord, CA
    2015 Prius Plug-in
    I hate to be pedantic, but:
    The kinetic energy of the car does not move about. The center of gravity moves forward slightly when you brake, as the front of the car dips and the rear of the car rises. Since all four wheels are in contact with the ground, technically you could regenerate using the rear wheels, but since more of the vehicle's weight is over the front wheels, it makes sense to apply the drag of regenerating to those wheels, rather than the rear wheels, where the resistance to rotation might cause the wheels to lock.
  9. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The Lexus LS 600h is some what different.
    It is equipped by a mechanical AWD with a center differential.
    Ken@Japan
  10. KTPhil
    KTPhil Active Member
    1,379
    22
    As long as the front and rear wheels are connected to each other via the chassis, it doesn't matter if 1, 2, or 4 wheels are used to capture the energy! There is no difference in efficiency.
  11. Tideland Prius
    16,602
    true that. My mistake.
