Pinging at high RPM?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by coonbutt, Dec 5, 2007.
  1. coonbutt
    coonbutt New Member
    40
    I have an 07 with about 15k miles. Lately, while accelerating up highway on ramps (or similar), I have been noticing some pinging or knocking from the engine at high rpms. This has happened through a couple of tanks of 87 octane gas, from the same station. The gas station is very popular and gets its underground storage tanks refilled very often, so it certainly isn't skunky gas. I plan to use another gas station when this tank is full at check for changes.
    Does anyone else have this problem? I can't stand the thought of pinging on a motor with just 15k miles on it. :mad:
  2. richard schumacher
    7,664
    1,045
    United States
    If it really is pinging and not some other noise, then it needs service. High octane gas will only mask the underlying problem.
  3. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    My wife was actually read the manual the other day:rolleyes:, and she said it said 87 octane was OK to use, but they recommended 91.
    It may just be an octane issue, especially with the winter gas that's out now.
  4. bwilson4web
    16,126
    engine knock sensor
    One possibility is the engine knock sensor may have failed. This would prevent the engine controller from adjusting for the gasoline octane. I'm not sure how to test it.
    GOOD LUCK!
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Huh? I thought they specifically DISrecommended higher octane.
    _H*
  6. qbee42
    3,079
    That was my impression too.
  7. bat4255
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    This is what my wife told me she read. I will verify
  8. richard schumacher
    7,664
    1,045
    United States
    It does? On what page? The 2004 manual recommends 87 octane unless you're at high altitude, which does not include any part of Cheesehead Country :_>
  9. bat4255
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I'm at work right now, but when I get home I will look myself. I can scan the relevant page and post it if that is what it really says. Give me about 10 hrs.
  10. N3FOL
    N3FOL Member
    891
    Stewartstown, PA.
    Fuel -
    My owner's manual for my '08 only states 87 (regular) octane. Nothing was mentioned about 91 Octane/premium gas.
    :rolleyes:
  11. bat4255
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Hmm, women
  12. bat4255
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    She was wrong (hmm), probably got confused with (Research Octane Number 91) :rolleyes:
    Sorry
    Page 472 (Excerpt)
    Premium unleaded with an Octane Rating 87 (Research Octane Number 91) or higher is required for optimum engine performance.
    If your engine knocks:
    Consult your Toyota dealer
    You may occasionally notice light knocking for a short time while accelerating or driving uphill.
    This is normal and there is no need for concern.
  13. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Pretty much anywhere we drive on vacation involves a mountain pass or three, and I really notice the reduced power at altitude. A turbo or supercharger to compensate (ok, maybe even over-compensate a little) for the thinner air would sure be nice.
  14. coonbutt
    coonbutt New Member
    40
    Thanks for the replies. Maybe it is the winter gas? I will need to fill it up again in a couple of days. Right now there is BP gas in it (which is the cheapest station in town, and I have a 5% gas card), but I'll try some Shell this time and post the results...
  15. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    are you using high octane?
