Lower octane gains MPG'S?
Discussion in 'Gen 2 Prius Fuel Economy' started by edthefox5, Dec 7, 2007.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Hi all,
    Lurking long time, member not so long so this might have been addressed before. Since I bought my 07 pack2 3 months ago I have been putting in 93 Octane gas. I was thinking I was being good to it during its break in. It has 2900 miles on it. And since I haven't really filled it up that many times the $$$ difference was not out of hand. 3 days ago at a fill-up I filled up an empty tank with 87 Octane. Always the same gas station. My average mpg meter has been showing 45-47 since new. Now 5 miles down the road after the 87 octane fill up I look at the meter and its jumped to 54 mpg's and has leveled out at 53 mpg's 200 miles later. Is the car that much more efficient at 87 octane?
    Its been colder here in Florida too so my mpg's were going down not up! Wow this is very cool! I am going to re-read the manual tonight as I think I remember it says what octane to use. Its the only car owners manual you must read. Thank you.
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I always understood lower octane was more volatile than higher octane.
    It is a misconception that higher octane has more power than lower octane. In reality, higher octane requires more energy to ignite it. Similar to diesel fuel, but not that extreme.
    Some racing engines use octane up to 100+ because their compression is a lot higher. The higher pressure causes more heat, which can cause pre-detonation (pinging), if the octane is too low.
    Higher octane requires more heat to ignite.
  3. qbee42
    3,079
    There is no advantage to using an octane higher than that for which your engine is designed. As the previous poster pointed out, it doesn't ignite as easily as a lower octane, so there may be negative effects.
  4. bwilson4web
    16,187
    energy content
    Testing in Huntsville revealed that three brands, Shell, Exxon and Chevron, have more energy in their 87 octane gas than other brands. Shell 93, 89 and Texaco 93 are low energy content fuels.
    GOOD LUCK!
  5. BoltonJoe
    BoltonJoe Junior Member
    55
    Massachusetts
    An Octane question
    Here's my question: Will burning one tankful of high-octane fuel damage a new Prius?
    I'm currently on the third tank of gas in my new car; when the gauge got down to one pip, I pulled into an unfamiliar station, thinking it would be the usual self-service place. Instead, an attendant ran out and asked in broken English if I wanted a fill-up. I said yes, adding: "regular please."
    When he handed me my card receipt, the attendant mumbled "I'm sorry, sir." I didn't realize what he meant until I looked at the receipt: I had been charged $3.29/gallon (for high-test), instead of the $3.09-per-gallon regular that I thought I was buying.
    Anyway, my engine has just reached the break-in point, and I've been happily watching my mileage climb from 39.4 mpg for the first tank to 45 or so for the second. Now, on my third tank, I'm getting 49.6 to 48.4.
    Is it the octane, the engine getting broken in or my greater experience driving a Prius that's responsible for the great mileage? And, once again, will I damage this wonderful car by burning high-octane for one tankful?
    Thanks,
    --Joe
  6. brick
    brick Active Member
    1,083
    79
    Upstate NY
    High-octane gas won't hurt anything except your fuel economy. Worst case scenario is that it takes a tank or two of regular gas after this one for the fuel maps to optimize back to 87 octane. Mechanically the car can handle it as well as any other pump gas.
    Too bad the town of Bolton doesn't allow self-service gas pumps. Stupid ordinance, predictable results. (I'm a Bolton expatriate.)
  7. BoltonJoe
    55
    Massachusetts
    Don't blame Bolton for this one
    Hey Brick:
    Thanks for the encouraging words about my not damaging my new car.
    How surprising to find an ex-Boltonite in South Carolina (are you a refugee from the collapse of DEC and the "Massachusetts Miracle"?).
    Actually, the station in question was on Morrissey Blvd. in Dorchester. Most stations in that part of Boston are self-serve. It was just my bad luck to hit this one--never again!
    Anyway, thanks.
    --Joe
  8. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi edthefox5,
    In many places the octane additive is Ethanol. Ethanol has a much higher octane than regular gas, but also much less fuel energy. This explains the difference you see.
    If an engine was designed to accomadate the increase in octane, its possible to recover more energy from the fuel. With a 100 % ethanol fuel, and car designed to take full advantage (increased compression ratio or higher turbo waste gate setting) the mileage decrease is reported to be less than that which would make the ethanol cost uneconomic.
    Unfortunately, no cars marketed in the US right now have this capability. The next gen Prius prototypes are reported to have a turbo, which could be controlled to accomadate fuel Octane.
    On a side note, gas dropped 10 cents a gallon here in Chicagoland, in a week. And Diesel went up 50 cents a gallon. I presume that means we are now running on winter blended fuels. The gas is probably cheaper as it now has 10 % ethanol. And my mileage tends to confirm that, although the multiple 20 degree F startups, and the one 10 degree F startup probably has something to do with it, besides the tire pumping snow out the way on the part of one trip.
  9. mldoc
    mldoc Junior Member
    28
    Riverdale, NY
    If the buck or two is worth it to you, you might want to consider disputing the difference with your credit card. If nothing else, the nasty letter that the gas station will get from the credit card might get them to be a little more careful next time.
    I was always under the impression that higher octane gas takes longer to burn, and is therefore less explosive than lower octane gas. Again, this is necessary in a high performance engine bu it does rob power.
  10. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Thanks everyone for the weigh in but although I have gained maybe 4 mpg's almost instantly the car does not have anywhere's near the pick up it had. In fact it feels like all of a sudden there's alot of weight in the car. Its not pinging or running bad just doesn't have as much power as it did when running 93.There's really no debate about it as its quite evident to me. It's a pretty quick little car running 93 but now running 87 to pass a car I have to dig into the gas pedal alot more...the engine really rev's up but not going anywhere fast. I can live with it as it's still a very nice driving car but I just thought it was real cool that in 5 miles the car re-calibrated itself to the new octane rating on board.
  11. N3FOL
    N3FOL Member
    891
    Stewartstown, PA.
    87 Octane
    I also think that one may get more mpg in using 87 octane. With the Prius engine, it is not highly recommended to put 91 octane and with fuel economy in mind. I am on my 4th tank and had always used 87/Shell. So far so good and averaging 46 mpg - mostly interstate ride.
  12. F8L
    19,011
    4,083
    Grass Valley, CA.
    The only reason I could see a Prius needing 91/93 octane is if it is a VERY high milage engine with lots of carbon buildup on the pistons which would could cause preignition.
  13. MattFL
    MattFL Member
    187
    55
    octane and mileage not related
    My understanding is: The octane rating of a fuel has nothign to do with the energy density of that fuel. Octane relates to the fuels resistance to ignition. The higher the octane, the higher the resistance. This is why higher octane fuels resist preignition (burning before it's supposed to) and detonation (burning too fast and uncontrollably). Preignition can raise engine temperatures and reduces power output and efficiency. Detonation often results in pinging and knocking noises, which are actually caused by the shock wave from the sudden explosion hitting the piston and head. Detonation damage to an engine is caused by too many repeated sudden explosions, which can actualy lead to holes in the pistons if allowed to continue. Most modern cars have ping and knock sensors that the computer uses to detect detonation, and the computer then changes things such as engine timing to reduce the detonation before real damage occurrs. If you have an engine that is finiky about octane then higher octane fuels may allow the computer to run more aggressive settings which will allow your motor to produce more power. So in this case the additional power doesn't come from a more energy dense fuel, but from the fact that its resistance to preignition and detonation allows the computer to run more aggressive engine settings.
    So in summary, depending on the chemical makeup of the fuel, any given fuel may have a high or low energy deisnty regardless of its octane. However depending on the engine, higher octane fuels may allow the computer to run more aggressive and more efficient settings giving you more performance. The prius appears to be designed for lower octane fuels, so it's doubtful that higher octane alone would provide any benefit at all.
