New Article: The True Cost of owning a Hybrid
Discussion in 'Gen 2 Prius Main Forum' started by macreative, Nov 26, 2004.
  1. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    There is a post somewhere around about the prius being used as a taxi. The car outlived a conventional transmission. It still worked but they upgraded to 04 sor 05 models.
  2. prius04
    prius04 New Member
    1,161
    NorthEast USA
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(prius04\";p=\"53258)</div>
    sorry that falls under the powertrain warranty, it's not part of the hybrid warranty.
  4. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    The "transmission" is very, very similar to a differential.
    Have you ever heard of a differential failing? It's extraordinarily rare. So you have little to be actually be worried about. In fact, the odds of being in an accident that totals the car are probably much higher.
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Not to mention that it is virtually IMPOSSIBLE to strip the planetary gears. :) The computer won't allow it. Hmmm HAL is taking over ;-)
  6. DQ
    DQ New Member
    Victoria
    You mention that the vehicle outlasted the conventional transmission and then they replaced the vehicle with a newer model...
    Another taxi driver in Victoria BC has driven his 2001 Prius over 350,000 km. Toyota hasn't replaced his vehicle and his transmission is still going strong.
  7. john1701a
    12,820
    5,305
    58
    It wasn't a "replacement" as implied.
    The Prius that Toyota bought back from the owner was for the sake of research, a hybrid with a ton of real-world data for them to tear apart and study.
  8. V8Cobrakid
    3,790
    152
    At least i know my car will last 4 years. Currently i'm going to put about 60,000 miles each year on my car. Unless i get that other job.. then it won't last as long. lol
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    60,000 a year? that is over 150 miles a day... that is a lot
  10. V8Cobrakid
    3,790
    152
    yeah.. sometimes more than 150 a day. I should start a taxi company :) lol i travel about 45 miles to my work. Then i drive around all day for work. It's only part time right now though. On the weekend i travel about 50 miles to go see a friend. if i take any trips.. well.. that's even more mileage. Glad i drive a prius. We'll see how long it last.
    Oh.. if i get another part time job, that might be another 20-100 miles a day. I'll see if i get that job though.
    I wish i had a stable single job. lol my poor prius
