Day Mode option not working - 2008
Discussion in 'Gen 2 Prius Main Forum' started by MattFL, Dec 9, 2007.
  1. MattFL
    MattFL Member
    176
    49
    When my headlights are on and the touch screen is dim, I "thought" that selecting "Day Mode" would put it back to full bright, but it has no effect at all; the screen stays dimmed. Does anyone else have this issue with a 2008, or are there any known work arounds? Or perhaps am I misunderstanding the use of Day Mode?
  2. KAR IDEA
    KAR IDEA Member
    465
    Lake Peekskill, NY USA
    Three Touring
    The little dash light dimmer on the left side of the steering column. Push it all the way up and it will brighten up your day...I'm not dimmin' you. Figured this out yesterday.
    Dave
  3. MattFL
    MattFL Member
    176
    49
    You are correct about the thumbwheel, thank you very much. But isn't the "Day Mode" option supposed to do the same thing?
  4. KAR IDEA
    KAR IDEA Member
    465
    Three Touring
    Haven't read up on what day mode does...
  5. qbee42
    3,077
    The day mode switches the MFD back to day colors, and as I recall, restores the brightness of the display. I don't recall if it has any affect on the speedo VFD display or button back-lights.
  6. KAR IDEA
    KAR IDEA Member
    465
    Three Touring
    Thanks Tom...
