Factory Sirius Radio for Prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by Metro, Apr 24, 2007.
  1. twopul
    twopul New Member
    Kissimmee Florida
    Sirius radio installation for 2004
    Has anyone had any experience installing the Sirius Radio offered by Metro or Prius Chat in a 2004 Prius?
  2. bigbearballs
    bigbearballs Junior Member
    57
    Austin, TX
    Re: Sirius radio installation for 2004
    I'm wondering the same thing. Has anyone posted pics of their install?
  3. Rest
    Rest Active Member
    1,210
    53
    CA
    I am reviving an old thread.
    My Factory Interactive Sirius Satellite radio kit has been fine for almost 4 years now, in a 2006 Prius. But then yesterday the Satellite screen said it can't acquire a signal. It leaves me to believe that the Satellite box itself is fine, but that something is wrong from that box to the antenna. So I am going to have to remove the rear seat and get to the Satellite box that is near the left wheel well. Then I will trace the antenna wire back. I'm just hoping the problem isn't inside the Satellite box, as that's the most expensive part.
    Any suggestions? Anyone else have a similar issue with this kit?
  4. danix
    danix Junior Member
    31
    CA
    More likely it's the cable from the unit to the radio. Mine was stashed under the glovebox, bet yours is too.
  5. Rest
    Rest Active Member
    1,210
    53
    CA
    I installed the unit, but I don't think the issue are the wires from the Sirius unit (which is above the left wheel well) to the radio unit. If it were I would think the Satellite screen wouldn't come up at all. The screen says there is no signal acquired.
    UPDATE: My issued turned out to be the antenna as I suspected. I connected an antenna from a portable Satellite radio unit and the Prius Sirius radio now works fine. Looking over the defective antenna I can't find anything wrong with the cable or antenna itself, so I'm not sure why it failed. Interestingly, with the antenna unplugged from the Factory Interactive Sirius box the display on my Prius radio says "Antenna". Telling me an antenna needs to be plugged in. This is good trouble shooting info, should the antenna ever come unplugged.
    Also, I am not sure Factory Interactive is still in business. I have emailed them but have not heard back from them, even though their web site is still up.
    Now off to buy a permanent replacement Satellite antenna. Any suggestions?
