A solar-assisted Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by tochatihu, Dec 6, 2007.
  1. tochatihu
    tochatihu Senior Member
    9,744
    3,761
    Kunming Yunnan China
    2001 Prius
    Robert Bruninga posted a link to his website on the yahoo technical group. I found it very interesting, and got his permission to link to it here. Have a look:
    http://web.usna.navy.mil/~bruninga/APRS-SPHEV.html
    For now, one must further stress that nothing is being offered for sale.
  2. WARHORSE
    WARHORSE New Member
    418
    SoBe, FL
    the solar panels on the roof are cool
    The ones on the front hood are dorky looking
    and the dash looks like he stole it from Erkel
  3. qbee42
    3,079
    If you drive away from the sun, any Prius will be solar assisted. Granted, it's a very small assist, but I'm going to count those little photons smacking into the back of my black Prius. I probably get an additional boost from the re-radiated infrared.
  4. mrbigh
    3,686
    699
    Long Island, NY
    Hey, Mr Bruninga is a fine E.E. and an innovator, give him some credit for his technology ingenuity
  5. darelldd
    6,059
    389
    Northern CA
    On the car is simply the wrong place to put expensive panels. Park in the shade. Park in a garage... whatever. Too many ways to waste the panels that could be producing all day if they are properly oriented on the roof of your house.
    He's quoting the energy that the panels can create. After conversion and charging of the batteries - the extra eight and air drag is going to offset a large portoin of the gain. At best, you could probably end up with one free mile a day in perfect conditions. That's a bunch of money, energy and pollution (to make the panels) for one mile/day. I love the idea. And one day it'll probably work.
  6. WARHORSE
    WARHORSE New Member
    418
    SoBe, FL
    I read there are new panels coming that look like regular house roof tiles
    so maybe there will soon be photovoltaics that stick on and lay flat against curved auto surfaces
    Here are some solar panels done by Pininfarina on a Ferrari 612
    The install is much neater as the panels are under glass
    In this case the solar panel is used to run a fan to cool the cockpit
    I did a semester at the Art Center on Auto Design where I designed a solar electric hybrid, the car had a Large flat panel on the back to capture sunlight, the front sort of looked like an F1 car :)
  7. icarus
    icarus Senior Member
    4,884
    976
    earth
    Having lived off grid for ~15 years I have a few observations. If you are interested in solarizing anything, I suggest you visit:http://www.wind-sun.com/ForumVB/index.php. There is a world of very informed and usefull information.
    My sense is that you would be way farther ahead adding solar to your home or work place than the car. The panels and installation would be way cheaper for a similar out put. Panels need air under them to keep them cool as thier effeciency drops dramaticly with higher temps. (Thats one reason the solar roof tiles haven't taken over,,,they aren't nearly as effecient). Also the battery management systems are far simpler for either an off grid or grid tie applicaton.
    What solar newbies don't understand is how large (comparativly) the panels need to be in order to be effective. The little car icon represents 50 watt/hours of regen on the screen. A 50 watt panel in full sun, at optimum temp would put out 50 watts/hour. A 50 watt panel measures ~60"X16" depending on who makes it. If you do the math, you will realize how many panels it will take to give you any meaningful gain.
    The same money spent on solarizing the car would have a much better effeciency if the same money were spent on a fixed array, and then you plugged the car in.
    Icarus
  8. WARHORSE
    WARHORSE New Member
    418
    SoBe, FL
    photovoltaics are so 20th C :p
    This is 21st C solar power
    http://www.stirlingenergy.com/
    I believe you can build a smaller version to power your house & recharge your plug in hybrid
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    To add to darelldd's critisism, what are the coefficient drag losses by putting these panels on the car? I doubt they will be as seemless as sheetmetal and the texture would likely reduce aerodynamic efficiency. Maybe not as much as I think though?
  10. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
  11. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I believe the Aptera is supposed to have a solar powered fan to cool the interior when parked in the sun.
  12. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    Those kind of solar panel mounting solutions are great on an R&D basis, but for peak efficiency I'd be surprised to see any solar panel mounted at that angle producing more than 60% of it's actual rated capacity.
    Neat idea, but I'd rather install a solar array at home or a wind turbine, followed by buying a PHEV (if Toyota actually do bring them past the testing stage) or converting a regular Prius to a Prius +
