Complicated window washer handle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Carolyn Cadigan, Dec 11, 2007.
  1. Carolyn Cadigan
    Carolyn Cadigan New Member
    Rockford, IL
    I have to think WAY too hard every time I want to clean my windshield or rear window. Firstly, I cannot see the "handle" (for lack of a better word) behind the steering wheel to read it. Then I must take precious eye time off the road to read what I want to do. I end up spraying my rear window when I wanted to just wipe the windshield.
    I have a little code: I say to myself "Turnip" which means "turn up" the end of the handle to wipe the rear window. Opposite of that is "push down" for turning on the windshield wipers. I don't yet have a code for turning things off.
    Really shouldn't have to work this hard. Toyota, please simplify this.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You'll get use to it and it will become second nature.
  3. richard schumacher
    7,666
    1,047
    United States
    It took me only about three years to get used to it :_> But they did design it wrong: the control should not force you to wipe before you can spray.
  4. RinMI
    RinMI New Member
    132
    SW Michigan
    You would rather that it force you to spray before wiping, even if all you want to do is eliminate light raindrops?
  5. Tideland Prius
    16,623
    huh? Pull on the handle and nozzles spray the windshield before the wipers come on. Twist down on the tip and the nozzle sprays the rear window before the wiper comes on.
    I don't know about you but it's much easier to use Toyota's wiper system than GM's "smart" stalk.
    Why don't you tell us how a stalk (or a dial?!?) should be that incorporates:
    MIST, OFF, INT, LO, Spray and the variable intermittent settings PLUS the rear window spray, intermittent and constant wipe settings :)
    If you're expecting me to find a separate button for the rear window washer/wiper like I do on the Chrysler minivans (which are, for some reason, by your knee) then good luck.
  6. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    They did in 2004 when the rear wiper was an option. My car does not have one.
  7. richard schumacher
    7,666
    1,047
    United States
    Uhh... brain fart! I hate when that happens. Yes, the control does have the needed functionality. But I still wish it were arranged in the other direction (that is swap clockwise with counter-clockwise); as it is it just intuitively seems backwards.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    umm..what Tideland Prius said....
  9. agile pagile
    agile pagile New Member
    46
    Benicia, Ca
    No Brain Fart
    Thank you edthefox5. No brain farts from you!
