Blown center consol?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aolm, Dec 15, 2007.
  1. aolm
    aolm Junior Member
    85
    New Jersey
    My entire center consol is dark… MFD, clock and radio. I believe I have checked every fuse in my 05 prius. My 12v outlets work fine. This was caused by accidentally shorting my on/off wire on my amp.
    Any ideas?
  2. aolm
    aolm Junior Member
    85
    New Jersey
    Any ideas?
  3. fish_antlers
    fish_antlers New Member
    200
    Ca
    pay mechanic money?:eek:
  4. HighBreed
    HighBreed Member
    113
    Los Angeles/Orange Counties
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    it may be a grounding problem.. then again.. maybe not.
    where did you pull the 12v switched power from?
  6. brick
    brick Active Member
    1,083
    79
    Upstate NY
  7. aolm
    aolm Junior Member
    85
    New Jersey
    easy fix
    That thread makes is seem difficult to fix. My installer checked the fuses with a 12 v light pen attached to a ground wire. He checked the entire car in minutes by grounding the "pen" and then probing each fuse face left and right looking for a short. He did not need to pull an fuses. He found the bad 7 amp fuse and fixed it no charge. The fuse was under the steering wheel.
    One fuse controls the entire center console.
    I am glad to be back to full high power audio.
  8. aolm
    aolm Junior Member
    85
    New Jersey
    easy fix
    It was a bad fuse, fixed in minutes by my installer who has the right tools and knows what he is doing.
  9. N3FOL
    N3FOL Member
    891
    Stewartstown, PA.
    Fuse
    Nice to know that there is a fuse under the steering wheel. This may come in handy. Glad to hear everything is powered up and back to normal.
  10. Lloyd9
    Lloyd9 Junior Member
    88
    Vancouver
    Re: easy fix
    Any idea which fuse was bad? i have same issue, checked every MFD related fuse. all appear good. MFD, Radio and Clock off. Everything else appears to be working.
    thx
  11. Patrick Wong
    18,210
    6,515
    There are three fuses that supply power to the MFD:
    15A ECU-B
    7.5A ECU-IG
    7.5A ACC
    There are two fuses that supply power to the radio control head:
    15A DOME
    7.5A ACC
    Since you say that both the MFD and the radio are not powered up, check the 7.5A ACC fuse first.
  12. Lloyd9
    88
    Vancouver
    I located it as being the 7.5A ACC fuse
    No visual indication that the fuse was bad, but when a new one was used - it worked.
    Thanks
