Nokian WR 5K review
Discussion in 'Gen 2 Prius Main Forum' started by richardl, Dec 16, 2007.
  1. richardl
    richardl New Member
    As most people know, the OEM tires on a Prius leave much to be desired. So at 43,000 miles, with the tread worn down pretty far, I decided to buy new tires. I spent quite a bit of time on Priuschat researching which tires to buy. My main requirements were:
    - all season tires
    - not too much compromise in snow handling (i.e., wouldn't need specialized snow tires)
    After looking at HydroEdge, X-Ice, and a few others, I decided to go with Nokian WRs (185 60R15). I paid $560 total (installation and tires). So, after 5000 miles of driving, I have some thoughts.
    1. Virtually any tire you buy to replace the OEM tires will be a dramatic improvement over the OEM tires -- they're that bad.
    2. The Nokian WR tires are great.
    DRY: Overall, a little noisier. Some passengers notice it; most do not. It doesn't bother me, but it's noticeable. Handling and cornering are much improved.
    WET: This is where I noticed the biggest difference. With the OEM tires, my VSC would kick in fairly frequently on wet surfaces. This doesn't happen any more. I've driven in torrential rains and the handling is superb. The car sticks to the road and it feels dramatically safer.
    SNOW: Very good. I haven't owned another pair of snow tires, so it's hard to compare, but this morning I drove on roads with 2-3 inches of accumulation, with an additional 2"/hour coming down. I definitely noticed the snow (had to drive carefully and there was some slippage while turning) but I never felt out of control. I know this would have been impossible with the OEM tires (I never drove in these conditions with the OEM tires so I can't compare, since I never would have tried.) The car powers well out of snow when at a complete stop with minimal slippage.
    Overall, I'd strongly recommend Nokian WRs. If you don't get these, I strongly recommend tire upgrades if you drive in anything but San Diego weather ;-).
  2. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Richard has it right. My 2004 Prius now has 104k miles. The Integrity tires were poor in all aspects (even inflated to 42/40 psi) and I took them off at 44.5k miles. The Michelin MXV4+ "Energy Saving" tires (H-rated) I put on next were much better:
    1. Great handling
    2. good traction dry/wet, but only a little better in snow/ice
    3. About 0.5 MPG improvement over the Goodyear's.
    But are no longer available in our size (185/65R15).
    I took them off a little early (55k miles of wear, they could have safely gone 60k miles) as winter was approaching and put on the Nokian WRs (H-rated, they are also available as T-rated for $5-$7 less per tire - get the H - stronger tires). My results to date are similar to yours (also at 5k miles) so I am very pleased with them (my son-in-law just put a set on his 2005 Prius as well).
    It is early to quote accurate data, but the WR's appear to be getting better MPG than the Michelin's (both also inflated to 42/40 psi). So they are indeed LRR tires.
    JeffD
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    I'm intruiged by the MPG gain. Are you guys being very careful to account for any climatic, road surface, and driving technique changes that may have influenced the mpg difference?
    I know the Nokian NRT2 were rated pretty well for LRR according to Green Seal's .pdf but since the Integritys were not listed I couldn't compare. The Bridgestone B381s had a very low RR rating but I didn't see them in our size.
  4. jdenenberg
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you read my spreadsheet carefully, you will see a side analysis that compares the Integrity's to the Michelin's over a full year of use (each tire's last year - November through October). My driving habits are reasonably consistent year to year and I took into account each tire's revs/mile when new and adjusted for their tread wear (increases revs/mile in a predictable way, I am an engineering professor :)). Averaging over a full year does tend to average out the uncontrollable variables so the 0.5 MPG improvement is real.
    The use of organo-silicates (and vegetable oil in the WR's?) in the rubber compound seems to indeed reduce rolling resistance (especially in cold weather) .
    JeffD
    ps:
    1: This November was actually colder than last November (I track degree days in CT) and I took one of my regular trips to Chicago during a winter storm this month (December) which drove my MPG down so it does indeed look like the WR's are going to perform well in saving fuel.
    2: You can get relative LRR readings directly from Nokian technical support (at least between their tires). For example they told me that the WRg2's have the same rolling resistance as the WR's in response to an email query.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Sorry i didn't read the spreadsheet Jeff, I clicked on it and my WinZip program popped up and I was reluctant to add the file to my computer. *looks embarassed*
    Thank you for the detailed info.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Would it be worth asking Michelin (email) why this size has been dropped as it would find a market among Prius owners as it has shown to be a better tyre than the OEM tyre? This may influence them to restock them.
    Or are they available in 195 / 60R15? which has the same rolling radius near as sh** is to swearing anyway.
    Although I think the 185s would perform better in snow and ice than 195s, yes? no?
