1. PCV-III
    PCV-III New Member
    Ypsilanti, MI
    How does one remove the SPEAKER GRILL above the MVD ?
    If I hold my hand on one corner "the dratted rattle" goes away
    that I suspect the problem lies there-in
    Yes, ours is the 2006 machine :eek:
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Just pry up the front edge with a thin spatula or knife...comes up quite easily.
  3. efusco
    19,891
    1,196
    Nixa, MO
    BTW, while you're at it try disconnecting the speaker wires...you might find, like several of us, that you prefer the increased stereo separation you get by removing that speaker.
  4. SureValla
    SureValla Member
    590
    Shelton, CT
    really? you dont have yours connected?
  5. efusco
    19,891
    1,196
    Nixa, MO
    Hasn't been for about 3 years. It's not a true 'center speaker' as you'd expect in a surround sound system, it's just an equal blend of the front two speakers...hence it serves to balance the sound if you have a driver and passenger...but since I'm usually the only one driving I can shift the balance of the front two speakers so they're equal and disconnecting the center speaker gives much nicer stereo separation.
