Questions about new DICE Silver iPod controller.
Discussion in 'Gen 2 Prius Audio and Electronics' started by lalittle, Dec 21, 2007.
  1. lalittle
    lalittle New Member
    17
    I've been reading about the Dice Silver iPod kit and I'm unclear about the navigation and playback behavior. Note that I tried to find this information out on the Dice site, but the only manual I found is for the old "playlist limited" version.
    Here are my questions:
    1) Are you able to browse in multiple levels such as Artist>Album>Song? In other words, can I browse to the artist "The Beatles," then browse to the album "Revolver," then browse to a specific song and play it?
    2) Does it automatically just "Play" when I stop browsing, or can it wait until I specifically "play" a song or album? Do I understand correctly that if I just peruse the iPod via this system while a song is playing, I could unintentionally start playing a different song?
    3) Is this system's navigation response considerably faster than other systems that work on the 2005 Prius? The other systems are notoriously slow, and given that the Dice system will allow navigation of literally thousands of songs, it would have to be a LOT more responsive.
    4) Can this unit be set to allow control via the iPod, and if so, will it still display text information on the screen? (How many "modes" does this system offer.
    5) When controlling via the Prius nav screen, does the iPod screen still display the song information.
    Thanks,
    Larry
  2. strieby
    strieby Priusman
    76
    Bakersfield, Ca
    I was going to order one for my 2008 and spoke to the Dice sales guy. He said they are not selling any for that year for about 3 weeks due to issues with the programming. The 2008 aparently has changed some of programming and they are now trying to get it to work correctly.
  3. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    This is no longer the case. 08 models are not supported, with the Silver kit ONLY. The standard kit is not 08 Prius ready.
  4. Vagabond
    1,198
    Southern California
    Yup!
    If you stop on a selection for 2 seconds, it will begin to play.
    It's as fast as you can press a button. If you use it in SAT mode you can use the Tune wheel and then it's REALLY fast.
    Nope! With the Silver's, you can only have one or the other. Control from the car or from the iPod.
    No, it will say accessory attached. This is Apple's doing.
  5. mrbrown188
    mrbrown188 New Member
    17
    CA
    Hey Vagabond,
    Does the new Silver work with the 07 Prius ?
  6. lalittle
    lalittle New Member
    17
    Thanks -- I have some followups:
    So if you navigate a bit too slowly, it will start playing whatever is on the screen? When this happens, do you need to start navigation over again, or can you continue navigating from the current spot forward?
    Also, can you step back up to the previous navigation levels -- i.e. if you are playing a certain song by a band, can you navigate "back" to this band's list of albums, then select a different album and navigate "forward" again?
    Do I understand correctly that the only way to "select" an artist or album by waiting on that artist or album for two seconds? In other words, you don't have a "select" button like you do on the iPod, correct?
    I have a 2005 that does not have SAT. Does this make it slower than newer Prius models?
    How do you toggle this mode? Are there just these two modes?
    How do I find out about places that install this type of unit in my area, or where I might be able to actually see one in action.
    Thanks,
    Larry
  7. Vagabond
    1,198
    Southern California
    2004 to 2008, no problem.
  8. Vagabond
    1,198
    Southern California
    Current spot.
    Yup!
    No, you have to wait it out. There's no point in requiring a select key since there's nothing on the steering wheel to map it to.
    Your 05 does in fact support SAT mode. So no.
    You have to do it from the DICE kit. There's no on-the-fly switch.
    Any install shop can do this, this is a one-wire install and is pretty much the easiest radio mod a person can do. There's no place to see them in action, since it's brand-spanking new! When I get around to it we'll make a few videos.
  9. Tideland Prius
    16,674
    So how do you get the SAT mode? cause my current DICE kit uses the CD Changer mode (CD2). I have the JBL audio with 6-CD.
  10. mgipe
    mgipe New Member
    Where can I get one?
  11. lalittle
    lalittle New Member
    17
    If you use it in "button" mode, can you hold the button down to rapidly scroll, or do you have to keep pressing/releasing the button?
    How can I confirm this -- I don't see any buttons for "SAT" in our Prius.
    That said, if I'm mistaken and it's actually an 04, does THIS make it any slower?
    I'm confused because the VAIS units are notoriously slow when navigating large groups. Is the DICE Silver specifically different in this regard?
    Thanks again,
    Larry
  12. Vagabond
    1,198
    Southern California
    You press the AM button. It will active a SAT kit if you have one plugged in. In this case, the SAT kit would actually be the DICE piece.
  13. Vagabond
    1,198
    Southern California
    Here at the Priuschat shop! They'll be available there just as soon as we begin shipping!
  14. lalittle
    lalittle New Member
    17
    Does the DICE Silver support browsing by "Genre/Artist/Album"? This is by FAR the most common way I navigate since it makes the lists a lot shorter.
    Does it offer browsing by "All Albums" as well as by "Artist/Album"?
    Thanks,
    Larry
  15. lalittle
    lalittle New Member
    17
    Might there be a key on the display screen to map a "select" function to? The point would be to not have to wait for each selection to "take."
    Thanks again for answering all these questions,
    Larry
  16. Vagabond
    1,198
    Southern California
    By button mode you mean CD/Mp3 mode and you'll have to rapidly press it. Toyota's code does not allow for a 'repeat' command.
    I'm confirming it for you ;) All Prius models from 04 on up support Satellite, despite the button not being there or Toyota's claims. I have Sirius in my 05 for example.
    Nope.
    I'll say this about VAIS. They are great at the car side programming, but we're vastly superior on the integration and iPod side. I guess you'll need to be more specific, since I don't experience any slowdown issues.
  17. Vagabond
    1,198
    Southern California
    No Genre. You're the first person to ever ask for it!
    Yes it does. As well as All Artists & All Songs.
  18. Vagabond
    1,198
    Southern California
    No, since there are not free spots that exist in both CD and SAT mode that exist in the Toyota lineup for both single-line display and screened radios.
    If you're thinking it would be like First you would select the artist, then have to wait 2 seconds to browse the albums, this isn't the case. If you select an artist and want to browse deeper, just move on to albums, songs etc and it will load them up without a need to wait.
  19. lalittle
    lalittle New Member
    17
    Thanks again for all your responses here. I'm thinking that this might be the best unit for my needs, but I'm still unclear on some of the functionality/behavior specifics, and my decision will be based on these specifics. For example:
    You're right -- I was fearing that you'd have to wait for each selection before moving to the next. That said, exactly how do you "move on" to the next level? In other words, if I navigate the list of artists, how do I "select" an artist and view their albums?
    Is there any way to browse while listening without accidentally "selecting" and playing another song? I sometimes just want to look around, but I don't want to stop listening to the current selection, and I might end up wanting this song to continue. I "sounds" like this might be a problem with this unit given that the "select" operation is to just stop browsing. Is there a way to "cancel" a browse and return to the "Now Playing" screen. (On this note, is there a now playing screen that is different from the browse screen?)
    Thanks,
    Larry
  20. lalittle
    lalittle New Member
    17
    Wow -- that must be a fluke, because in my experience, the most popular way to browse songs by FAR is Genre > Artist > Album > Song. This is the "default" design of pretty much every music library software out there, such as iTunes, JR Media Center, etc. I have several hundred artists and albums on my iPod, and I pretty much ALWAYS go through "Genre" first since otherwise, there are just WAY to many items in a list to browse. Now that the 160Gig iPod is standard, this number is going to go WAY up. Using "Genre" is an effective way to instantly narrow down the list.
    Is there any possibility of adding the ability to browse by Genre > Artist > Album? I guarantee that it would be used by a LOT of people if you did this.
    Thanks,
    Larry
