BMW Hydrogen Power
Discussion in 'Other Cars' started by WARHORSE, Dec 23, 2007.
  1. WARHORSE
    WARHORSE New Member
    418
    SoBe, FL
    http://www.theautochannel.com/news/2001/01/08/012373.html
    BMW has built a fleet of 7 series flex fuel cars they are testing around the world
    These cars can run on gas or Hydrogen but the big difference is that instead of a fuel cell for power the hydrogen is burnt in a conventional internal combustion engine and the exhaust is water
    the engine has to be modified as H runs hotter than gas but it seems like a good idea that is lower tech than the H fuel cell cars
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I'm not at all convinced of the merits of using hydrogen. Whatever power source is used to generate the hydrogen could be used to generate electricity far more efficiently and cheaply.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    SO we take a fossil fuel(natural gas), pump a heap of electricity into it to split the hydrogen atoms from the carbon and sulphur atoms, then pump it into an engine with about 20% thermal efficiency.
    Now that sounds like a plan!!
    What is the point?
    I had a Toyota Crown that ran only on liquid propane, propane is 3 carbon atoms to 8 hydrogen so I was 2/3 the way there back in 1990 and I was no trail blazer.
  4. WARHORSE
    WARHORSE New Member
    418
    SoBe, FL
    Um, yeah, the point is that we can keep older cars w gas engines and make them run cleaner & pollute less
  5. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Wouldn't converting those older cars to run on electricity be even cheaper? And because most of a car's lifetime energy use is in the driving, not the creation, wouldn't we be better off recycling the whole car?
  6. Tideland Prius
    16,623
    A flex-fuel is good. Helps bridge the gap.
    I believe BMW is leasing these cars out now.
  7. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Flex-fuel's not such a bad idea, but I think electricity is a better choice than hydrogen for the flex part.
  8. Trollbait
    12,691
    I would think replacing the fuel system would be cheaper than the engine and all its component parts.
    The electrical option is the better one, but there will be people who can't afford to recycle and upgrade. Of course, they won't be getting ICE bimmers either.
  9. naid
    naid Junior Member
    31
    CT
    That article seems to be from 2001. I haven't heard anything about BMW hydrogen-powered cars, maybe the project didn't go as planned?
  10. WARHORSE
    WARHORSE New Member
    418
    SoBe, FL
    its in this months POPULAR MECHANICS
  11. daniel
    14,487
    1,519
    Spokane, WA
    The real point of this is that if you are going to waste energy producing H2, and if you are going to spend the trillions of dollars building a distribution infrastructure for it, you don't have to spend ten million dollars per car building fuel cells; you can burn it in a conventional car with relatively minor modifications. It still makes no sense, but it's a lot cheaper than fuel cells.
  12. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  13. hill
    8,936
    The propane will do just find for your ol'junker. Hydrogen? You'd get less than half the range of propane.
  14. daniel
    14,487
    1,519
    Spokane, WA
    Yeah, but with H2 you could drink the water that comes out the exhaust. :rolleyes:
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    hehe.. true
  16. patsparks
    10,664
    567
    If you like oily water.
  17. WARHORSE
    WARHORSE New Member
    418
    SoBe, FL
    if you use a modern engine and it is running correctly you should not have any oil in your exhaust
  18. hill
    8,936
    Besides propane as a better / current day technology, one can use CNG as an alternate fuel in your older car, both being far superior than hydrogen. Sheesh, why waste natural gas, processing it into hydrogen, when the same energy you'd get from the natural gas would get you down the road WAY further then the hydrogen would? I'd think Chrysler, GM, BMW, Toyota, Mercedes, etc would be embarraased to admit they're wasting perfectly good research dollars on "hydrogen ... the perfect fuel" (in just another 10yrs from now).
  19. jammin012
    jammin012 The man behind The Man
    510
    Cali
    How about instead of hydrogen being a "flex-fuel" it IS fuel. Put the water in the tank, drive and drive and drive. Still have your old ICE and it'll sound just a cool too.
  20. jammin012
    510
    Cali
    I've been driving Ford's CNG for years and... it's ok but don't let the gas gage go down, there's no "reserve" like with regular fuel. Besides where's the closest CNG fill station?
