Rachet sound in drive train
Discussion in 'Gen 2 Prius Technical Discussion' started by Ray Moore, Dec 20, 2007.
  1. Ray Moore
    Ray Moore Active Member
    857
    52
    I have developed a quiet ratcheting sound when turning and accelerating uphill at the same time. This happens most when turning right. I do not accelerate rapidly. It does not seem to happen when hard accelerating on straight level roads. It sounds like a cv joint to me but I'm not a cv joint expert. Has anyone experienced this. A long search of past threads here turned up nothing on this.
  2. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    That does sound like a CV joint.
  3. MattFL
    MattFL Member
    193
    57
    I'm thinking the same. If you have some miles on it then a CV joint issue would be likely. Take a peek under the car and if any of the boots are torn or you see grease spread about then it's almost surely a CV joint.
  4. Ray Moore
    857
    52
    Does anybody know what the repair cost for this might be?
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    not sure on the cost of the axle, DH never priced one, but labor should be 1-2 hours.
  6. MattFL
    MattFL Member
    193
    57
    On our old Nissan 200sx (similar size engine) I think the replacement parts were under $100/side for rebuilt units. It comes as the entire axle and you give them your old one as a core. I would guess the Toyota parts might be similar in cost. I put them in myself so I don't know what a shop would charge for labor, but this is standard maintenance for any car that has this type of axle so if you call the shop or dealer they should be able to quote you a price over the phone.
  7. PoulStaugaard
    PoulStaugaard Now a PriusOwner
    95
    Copenhagen, Denmark
    Perhaps you should see a doctor about it :D.
