Prius Dead After Sitting 1 week
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dilbert, Dec 29, 2007.
  1. Dilbert
    Dilbert Junior Member
    44
    Seattle
    My wife returned home from vacation after a week and our Prius was dead (we thing a door was left open). She hooked up the battery charger at the low setting, which restores the interior power, but only gets the clicking of a relay whe she tried to start the car. The car will not "start" and there was a warning that the transmission has malfunctioned. I assume this car needs go be towed. Will the main battery really go dead if a door is left open? Anyone recover from this state on their own before?
  2. richard schumacher
    7,663
    1,038
    United States
    Sounds like the car was not shut OFF. If so then a tow to a dealer is in your near future. Bummer.
    After this is resolved, get in the habit of always locking the car no matter where you park it. If it is not OFF or if something is ajar it will warn you with a long beep.
  3. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Make sure you let the trickle charge work over night before you attempt another start.
    When you say that there is a warning that the transmission has malfunctioned, is the warning on the MFD? If so, did you have the door open when you saw this warning because when you have the door open while the car is on you get some arcane warning that could be interpreted as a transmission problem.
    Good luck. Keep us posted.
  4. Dilbert
    44
    Seattle
    I really don't think the car was left on. We left for vacation in our other car and this one was already in the garage from the previous night. I am not actally at home yet, and my wife knows little about cars, so it sounds like a tow. We decided not to leave on the trickle charge because here was a relay constantly tripping on and off when the charger was on and she could not get the car to "power down" either. The door could have been open. If I were home I would attempt to charge it, but I don't want her to take any chances. Thank goodness I got the extended warranty. We have had this 2004 for 3.5 years and it has 30,000 miles.
  5. TonyPSchaefer
    14,816
    2,498
    66
    Don't worry too much, Dilbert. I somehow managed to drain my 12v battery a couple years ago. After a jump start from AAA, all was well. In fact, I'm still running on that same battery even though some have told me to replace it. I just never got around to it.
    In short, this isn't a big deal. The hybrid battery is just fine. If your wife can't start the car (in my case, I had a heck of a time turning it off) than it's the little 12v and not the hybrid battery. After all, it's the 12v that actually starts the car.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You need to do what you feel you need to do, but this doesn't sound like a towing situation.
    I think you need a jump start.
    The only other thought I had is that your battery may be dead. I don't know what year/how old your Prius is, but you joined in '04 so it may be as much as almost 4 years old and the 12v could be nearing the end of it's useful life and not holding a charge well.
  7. Doc Willie
    1,717
    142
    Out there, somewhere
    Where are you attaching the trickle charger? If you are going through the cigarette lighter/power ports, it won't work.
    And a trickle charger may actually have enough juice to start the Prius if you follow the friendly owner's manual.
  8. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    A very low or dead 12 vdc battery will cause very odd system behavior.
    You can hook the charger to either the underhood jump point, or directly to the 12 vdc battery. The underhood jump point is easiest.
    I have posted in previous threads the TSB regarding how to properly charge the Prius 12 vdc battery. Toyota does recommend an automatic battery charger - one with their own brand of course! - at the 10 amp setting.
    A 12 vdc battery that has been in a dead state for a few days or longer, will need a lot more than 2-3 amps before accepting charge. For some truly dead batteries (Lights left on all day) I have had to use a 60 amp setting
  9. bigj3347
    bigj3347 New Member
    161
    Hacienda Heights, Ca
    I was out of town for three weeks and forgot to turn off the sks. When I got back, the sks was turned off but my car was able to start fine, you might want to get the battery checked. just my 2 cents.
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Remove the negative battery lead from the battery terminal, leave the charger connected directly to the battery for a few hours, reconnect the battery and try again.
    Good luck.
  11. dtetto
    dtetto New Member
    San Francisco, CA
    Hey all (just joined the forum today to ask a similar question):
    Our 2006 Prius was completely dead in the airport lot when we returned from an 8 day holiday. I didn't disable the smart key (didn't realize I could do such a thing) -- was this probably the cause of the problem?
    Probably unimportant sidenote: Initially, I thought that we had somehow in the rush to catch our plane left the car running in park and run out of gas in addition to killing the battery. Because when I tried to jump, the gas was flashing on E and as soon as we disconnected the booster the car would go dead again. We ended up going and getting a gallon of gas (the SFO parking staff was super friendly and gave us a lift in addition to the jump) and putting it in the car; afterwards, it jumped right up; but the gas was at more than 3/4 a tank. I say this is probably unimportant because the only rational explanation I can come up with is that I just somehow did something wrong during the first few jump attempts and the gallon of gas was just a placebo. But if anyone knows more about it...
  12. patsparks
    10,664
    567
    More time on the jumping car allowed more charge into the 12 volt battery which kept it alive. Extra petrol probably had no affect but it was fun going for it.
  13. Slartibartfast
    Slartibartfast Senior Fjord Architect
    61
    Twin Cities, MN
    Same problem here. On the Friday afternoon before Xmas, I gassed up and washed the Prius and parked it while we took the other vehicle on vacation. We returned 10 days later. During that time, it was in our garage. It's not heated but there are no noticeable drafts or leaks. The day I parked it, it was about 40 F. Most days the temperature hovered around 25/10 F with a couple nights dropping below 0. The day after we returned, I went out to start it and nada. Before we left, I checked the manual and this site about what to do before leaving the car parked for a while, especially in the cold. Even though I think I turned off the SKS (messed with it so many times this trying to see if I did leave it on), I can't be 100% sure that I did looking back. Both sets of keys came with us, so there was no problem with keys left in the house (though it's at least 20 ft from the garage to the nearest wall of the house anyway.). Nothing else was left on or open.
    So when my wife brought the other car back home that evening, I hooked her up and jumped it. I left it running a while to try to give it a recharge because I didn't have a charger and it was too late to try to take it for a long trip. The next morning, it was still dead, so I jumped it again, but with no luck. I was busy yesterday with other household emergencies, so I called for a tow this morning. The driver came out and put a battery pack on the front terminals and started it right up. I drove it for about a half-hour on back roads to a nearby dealer (not Burnsville) to try to warm it up and charge. When I got there I parked for a short time in the lot, then restarted. I figured it was fine, but I thought I should have them check it out since I was already there.
    They did and told me my battery was frozen and it wouldn't be covered under the warranty (only has 30k on it). I was diligent and did my research, I take good care of the car but there was nothing in the manual about this. I said this to the assistant (to the?) service manager, and he mumbled something about the ECU and how I should have put a trickle charger on it if I leave it more than a couple days, and sorry we can't help you, but we can order you a trickle charger over at the parts desk in addition to charging you $300 for the battery+labor. Even if I did leave the SKS on, I noticed that the manual says it shuts down after 14 days with no activity. Why isn't it 7 days if this is such a big drain? Why aren't there more warnings about the Prius 12V battery being more susceptible to freezing in colder climates. In the section on winter driving, it gives you tips about other things, but doesn't tell you to do anything special if you leave it for more than a couple days.
    Yes, this is my first winter in Minnesota. But I grew up in Michigan, and had visited this part of the country several times for work and family, so I know what cold does to cars and batteries. And had I planned to be gone longer than two weeks, or had Toyota told me that I needed to do it no matter what, I absolutely would have crawled in back and unhooked the 12V. Maybe I should have been more proactive, but I also get the feeling that the dealer was not willing to take the hit on the warranty. I know that TMS pays for the dealer for the repair but not at the full retail rate. I think someone saw the out of state (warm state) plate and thought they could get full price out of me. They did, but we're taking it up with TMS Customer Service to try to get a more complete, if not our preferred response.
    If anyone has words of comfort, advice, support, or shame, please feel free to share. Thanks.
  14. richard schumacher
    7,663
    1,038
    United States
    An undamaged battery should not freeze sitting in the cold for 10 days, so either it was defective, or it had been previously damaged (drained), or something was left on or open. Kinda hard to tell now from this distance...
    Did you lock the car before leaving? Had the battery ever been drained before?
  15. patsparks
    10,664
    567
    How old is the car? If it is 3 or 4 years old that is about the life of a lead acid starting battery anyway.
  16. Dilbert
    44
    Seattle
    I jump started it when I got home without any trouble and drove it around for a while. The next morning, however, it was dead again, so I took the battery to a dealer. They hooked up some kind of meter and said it only had 14% left. I am surprised that it only lasted 3.5 years, but I suppose it did not help it to be completely drained. A replacement battery by the way is $180. Thanks for all the good advice.
    By the way, is there any way to open a locked rear hatch with a dead battery? I had to jump it again in the morning to get the hatch open.
  17. efusco
    19,891
    1,192
    Nixa, MO
    Figured.
    Yes, but it isn't easy. Somewhere there are pictures of exactly how to do it, but basicly you have to climb into the hatch area (no small task), take off some of panel off, reach inside the opening behind the lock, feel for the release and activate it.
  18. jayman
    13,439
    640
    Winnipeg Manitoba
    When a lead acid battery is chronically undercharged, and then discharged and kept in that condition, there will be enough sulfation that your best bet is to just replace
    I was having trouble with my Prius the first winter. The cold temps, Max Heat, and constant electric defrost all took their toll on the 12 v battery. It got to the point that when I powered up in the underground parking, the auto headlights would badly dim once the coolant pump turned on
    I had picked up a few VDC battery minder's at auction, and was going away for over a month on business. I took the battery out of the Prius, carted it up to my suite, and left it plugged into the VDC the entire time I was gone
    I had to return early due to a family tragedy, but was gone almost 3 weeks. When I put the battery back in and powered up, the auto headlights barely flickered.
    I rigged up a harness that I run out the rear hatch when parked. I'm now in the habit of plugging in the VDC whenever the car is parked at the house, especially overnight.
    Original battery, still strong
    I also use a battery minder on my FJ, and noticed it cranks much faster.
  19. jayman
    13,439
    640
    Winnipeg Manitoba
    Let's face it, some dealers just don't give a s***.
    A badly discharged lead acid battery will freeze, which is almost always fatal to the battery. I also had to take steps to keep my Prius battery properly conditioned.
    Some folks appear to have no issues, others have a lot of 12 v issues. The PDI has been covered in a TSB that warns how essential it is to ensure the 12 vdc is properly charged before delivery or after major servicing. That tells me the constant voltage charge source will only keep up a battery in good charge and condition
    The TSB states an automatic battery charger set at 10 amps is to be used. The charger is branded Toyota but made by Associated Manufacturing.
    If the forum bugs are now fixed, I would like my attachment restored so I could attach the PDI pdf
  20. jtom888
    jtom888 New Member
    Long Island, NY
    2002 Prius
    Jayman, which VDC Battery Minder model do you have? There are few to choose from and I'm not sure which one to get.
    Thanks.
