2008 Prius Touring wheel offset?
Discussion in 'Gen 2 Prius Technical Discussion' started by cohland, Jan 1, 2008.
  1. cohland
    cohland New Member
    Oregon
    Does anyone know the offset of the factory-supplied alloy wheels on the 2008 Prius Touring?
  2. sleeka
    sleeka Member
    249
    Brisbane. Australia.
    Anywhere between 35-40 mm offset will be fine for a Prius.
  3. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    What are you thinking of putting on?
    Btw: That was my first post!
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The OEM wheel specifications are PCD=100,# of holes=5, offset=45.
    15 inch standard:15X6JJ
    16 inch Turing:16X6JJ
    Ken@Japan
  5. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    whats the maximum offset we can run for front and rear?
    i know the rears can take more
