2003 versus 2005 Prius
Discussion in 'Gen 2 Prius Main Forum' started by rkimages, Jan 2, 2008.
  1. rkimages
    rkimages New Member
    I am trying to decide between a 2003 Prius, which is around $10,000 and 2005 Prius, which is around $15,000. The 2003 would be purchased from a individual and the 2005 from a dealer. They both have about 70,000 miles.
    Is the 2005 model considerably better and worth the extra money? If so how?
    If I buy the 2003 Prius from the individual, how can I get a warranty?
    Thank you.
  2. aaf709
    3,862
    2022 Prius Prime
    Well, for one thing, the 2005 is a Gen II, while the 2003 is a Gen I.
    The 2005 has a split rear window, while the 2003 is solid in the lower part.
    Out of curiosity, what options does each have?
  3. Tideland Prius
    16,553
    Pros:
    • sedan (if that's what you want)
    • privacy of a trunk
    • ridiculously small turning radius
    • spacious interior for its exterior size
    • airy dashboard
    • side airbags were available as in GPS
    Cons:
    • it's using an older THS system
    • has an older battery technology
    • no folding rear seats
    • hybrid powertrain close to end of warranty (in terms of years)
    2005
    Pros:
    • hatchback design
    • fold-flat rear seats
    • more powerful and more economical
    • spacious
    • newer technology (smart key, bluetooth, backup camera etc)
    • Stability control and side/side curtain airbags are available
    • newer HSD system
    • Touring edition with upgraded suspension and tyres
    Cons:
    • larger car (if that matters)
    • larger turning radius
    • more common
    • hatchback design (if you hate hatchbacks)
  4. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    70k is allot of mileage for the 2005. It's even high for a 2003. That being said, the 2005 if it is in excellent condition should be about $17K the 2003 as a private party sale if it is in good condition is worth about $11k. In either case I would have the cars checked out before agreeing to either. My preference would be the 2005 as it is a Gen II and has a much nicer ride and has more room in both the trunk and cabin. I would also look further you might do better with a lower mileage vehicle for slightly more money.:)
