sharkfin question... can i add copper?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Stinky Pierre, Jan 7, 2008.
  1. Stinky Pierre
    Stinky Pierre New Member
    i just ordered the sharkfin antenna, and was wondering if someone could tell me the pros and or cons of adding a bunch of like copper scrubbies(for dish cleaning)or perhaps some other fine copper stuff into the sharkfin.
    would this help to improve the decline in reception that other users have mentioned after switching from the OEM antenna?
  2. RonH
    RonH Member
    556
    If you talking about just stuffing it in there it may block reception. Google Faraday cage. Soldering a length or coil of wire onto the end of the pcb board's antenna may help...or not.
  3. Stinky Pierre
    thanks RonH ...all feedback is greatly appreciated!
    well i googled faraday cage and after having read a few pages
    it appears to me that the faraday cage is more of an inclosed area to keep out low level interference in order to test wireless transmissions???
    and as far as attaching to the antenna couldn't i just "reveal" a little of the antenna coil and let it rub. maybe seal the whole deal with some plastic of sorts.
    kinda like when you put aluminum wrap on the old rabbit ears...and the picture would come in better...
    any other input from antenna junkies?
    any more thoughts ...anyone :)?
  4. RonH
    RonH Member
    556
    When it comes to antennas, length counts a lot. That's the reason the OEM antenna performs better than the sharkfin. However, there are tricks usually involving loading the antenna or providing a good ground plane. I'm old enough to remember using tin foil on rabbit ears. As I remember it was flaky as all get out. A car is probably not a good platform! Best not to glue it down until you're done experimenting. Good luck.
  5. richard schumacher
    7,663
    1,040
    United States
    As RonH wrote, length counts for a lot. All else being equal the sharkfin can't perfom as well as the OEM antenna for AM or FM reception. Stuffing it with brillo pads will probably make it worse.
    The roof is a fair ground plane. You might improve the sharkfin a bit by moving it to the center of the roof, but I'd expect it's not worth the bother.
  6. dumas
    dumas Junior Member
    44
    NC
    I figure the same argument applies here as with those cell phone "reception improvement" stickers - if adding a nickel's worth of foil or wire would make them work better, the manufacturer would already be doing it.
  7. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    There are two things you want with an antenna.
    First, it should be "resonant" over the frequency band you're interested in. This is usually done on FM but not on AM, because in order to make an AM antenna resonant, it would have to be very large. The exception is the old transistor radio ferrite antennas, which are resonant, but still a little bulky. On FM, size for resonance is achievable. The sharkfin, however is a little small, and would need a coil of some sort to make it resonant. As I haven't seen one I can't comment on whether they have done this.
    The second important thing after resonance, is size. The larger the antenna, the more wavefront it intercepts or gathers. So a small antenna will gather a small amount of signal. There is no way around this. In the Prius, there is an amplifier, in the roof liner, I think. But you are still working from a low signal level, which will mean noise when it gets too low.
    Reality bites. Sorry about that. When you install the sharkfin, you -may- be able to optimize its' function by making sure the ground point is well connected to the car roof. Short (no loops) connection straps may help here. Use something to reduce corrosion at the connection, such as silicone dielectric grease (it's clear). Other than that, there isn't much you can do.
  8. Stinky Pierre
    thanks all ...for your replies ...that is the knowledge i was looking for...i kinda figured that would be too simple:) but had to ask
    thanks david...
    i'll play around with it when it gets here ...in the next month
    we have a bunch of recycled copper wire my wife uses for art projects from time to time...if i notice anything interesting i will post it...
  9. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    I just got my sharkfin antenna yesterday, and when I looked at the underside of the sharkfin I had the same question as this thread title.
    Here's a picture:
    [imglink]http://priuschat.com/forums/attachment.php?attachmentid=16108&d=1246343772[/imglink]
    As you can see from the picture, the copper, grid-like antenna wire is only on one side of the fin.
    How come Visual Garage didn't extend that copper, grid-like antenna to the other side of the fin ... would not such a doubling of the copper wire increase the reception significantly ... should I try to do it myself (not with a copper scrubbie, but with something similar to the original copper, grid-like antenna wire)???
  10. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Boo,
    The copper scrubbie is a thing you clean grease out of pots with. These are randomly oriented copper ribbon, shaped like a sponge. They also come gold plated, although the plating is probably just "flash". Either type would screw up the tuning apparent in the Shark-fin antenna.
    Having worked on antenna professionally, I do not have much good to say about the antenna you posted a picture of. So I wont. Does it work on AM at all ?
  11. patsparks
    10,664
    567
    Adelaide South Australia
    I'm sure from memory my shark fin has a lot more "stuff" inside it. There were 2 antenna in mine from memory and a small circuit board.
    I can pick up a Victorian AM radio station on mine. Victoria is at least 200km away from here.
  12. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Well that would add 100% more copper, to that ridiculous little amount that is already in there, thus doubling the cost of that piece of crap!!!
    As stated before, if you want more signal, put up more metal!
    Brillo pads, with/without soap, do not count, shavings from a "Mill" do not count
    Looking cool, and receiving stupid, just does not make RF sense.
    I have been in the "RF" game for over 40 years.
    Some laws of Physics you can just not violate and get good results!!!
  13. Boo
    5,051
    485
    97
    Flushing, NY
    donee and patsparks,
    My sharkfin antenna is made by Visual Garage and sold by PriusChat Store and others.
    It's the same one that's been the subject of many threads and posts here.
    patsparks -- after posting the interior picture of my sharkfin, I found photos of the insides of other people's sharkfin antenna and they all looked like mine -- with the copper antenna grid on only one side of the fin. See, e.g., our friend, darelldd's sharkfin:
    [imglink]http://evnut.com/images/prius/antenna/shark_fin02.jpg[/imglink]
    So, I'm still wondering if I can improve the reception by just taping some additional copper wire to the end of the existing antenna grid and looping and taping that additional wire onto the other empty side of the fin. At minimum, I don't want to cause any harm.
  14. leftie1277
    leftie1277 New Member
    63
    Boston, MA
    I have that same sharkfin installed and I have NO PROBLEM with AM or FM stations, sounds just as good as the OEM antenna
    -Matt
  15. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Boo, let us know how your reception is because I really would like to get one if it works well.
  16. KK6PD
    4,003
    944
    118
    That's because you live in town and the ERP of the the stations you listen to have enough power to overcome the deficiencies if the "Sharkfin"
    Try driving 40 or 50 miles out of town, and see how the reception is.
    It all depends, on ERP, AM/FM, distance to transmission tower, what's between you and the transitter, and the type of receive antenna!
    It's like walking into a forest and looking for a tree, your pretty much guaranteed your gonna find one. However walk up and over the hill into the desert 50 miles away, your not gonna get a lot of trees, just sand. The tree's you do find are all scrawny and crappy !!!
    RF is simple!!
  17. Boo
    5,051
    485
    97
    Flushing, NY
    So KK6PD, what do you think of my idea of just attaching more copper wire (such as home radio antenna wire, speaker wire, lamp wire, etc.)?
    Should it help?
    Can it hurt?
  18. KK6PD
    4,003
    944
    118
    Lets try a Positive approach.
    What do I really need to do to "Sharkfin" antennas to make them more efficient.
    If you follow RF theory, perfection would be a full wavelength antenna. The FM band in the U.S. is 88Mhz to 108Mhz. Thats a 20 Mhz spread of frequencies. For reference lets take the middle of the band, 98 Mhz. In inches, the a full wavelength antenna would be 120.489 inches long. Nice thing about RF is that if you start 1/2ing things, it still will work out rather well. So a 1/2 wavelength is going to be 60.244, and the most used auto wavelegth is 1/4 wave which woud be 30.122 inches. Measure the length of the copper circuit trace in the sharkfin, if it comes out to 12 inches I would be surprised.
    At this point I have to add another variable into the mix.
    Sorry, it's called Antenna Polarization.
    In the early days of FM radio in the 88-108 MHz spectrum, the radio stations broadcasted horizontal polarization. However, in the 1960's, FM radios became popular in automobiles which used vertical polarized receiving whip antennas. As a result, the FCC modified Part 73 of the rules and regulations to allow FM stations to broadcast RHC or elliptical polarization to improve reception to vertical receiving antennas as long as the horizontal component was dominant.
    To improve the antenna to 1/4 wavelength spec you should ADD aout 20 inches of copper in the pod. I would take some #20, or #22 Guage coated wire and glue it into the "Sharkfin in an up and down arrangement. High Temp Hot Glue would work OK. make sure you solder one end of the wire to the end of the trace on the copper foil. Do not overlap the wire, the spacing could be tight, but thats why your using insuated wire, that, and for corrosion protection. That should help with the range issue.
    Note also the Prius has an RF pre-amplifier in the base of the existing mount. If the RF Pre-Amp goes south, so does radio reception.!! Its purpose is to amplify small RF signals. Make sure yor antenna extension does NOT come into contact with the chassis ground.
    Somebody try ths, and take a drive that you nomally have a station you listen to fade away and see if this improves things a bit??
    Here is the time for bonus science points folks, let's all play Mr Wizard!!!
  19. KK6PD
    4,003
    944
    118
    Boo, that's funny, as I was composing, you post this!!!
    Yes I think it could help quite a bit. be very inexpensive, and produce positive results!!
    Lemme know how it goes!!
  20. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Boo, et al,
    IIRC, there are two antennas (antennae?) in the SharkFin.
    One, folded in a regular rectangular pattern, has been pictured.
    There is I believe a second one on the small green circuit board affixed
    to the flat after surface of the fin. This one is folded "fractal" style, and
    looks for the world like an aquarium snail's feeding track.
    Don't know which antenna is AM or FM.
    Maybe one of the ee-smart members could confirm/deny/explain.
