Few Quick Questions
Discussion in 'Gen 2 Prius Technical Discussion' started by DeekoPete, Jan 19, 2008.
  1. DeekoPete
    DeekoPete New Member
    Wisconsin
    Ok, I did search for these questions and did, in fact, find a few answers, but I was wondering if anyone could elaborate on a few things for me. Yeah, I'm a noob, but hey, I'll freely admit it.
    1) My brakes makes a strange sound every now and again, especially when I'm simply using the battery power to cruise towards a stop. Is this buzzing-type noise normal? I don't notice it if I'm using the gas engine.
    2) The car drifts ever-so-slightly to the left. I'm assuming this is simply due to it only having eleven miles on it when I bought it and I'm guessing they didn't check it once it got off the truck at the dealership, but I just wanted to see what others thought (if this is a fluke).
    3) (Last question for the night, I promise). When I tap the touchscreen icon for "Maintenance", it usually sends me to the nav system. If I go back and do it again, I'm can access "Maintenance" no problem. Hiccup in the system?
    Thanks again for all the answers! This forum is really great! :)
  2. frosh
    frosh New Member
    35
    Virginia
    check you tire pressure
    frosh ;-)
  3. DeekoPete
    Wisconsin
    Yeah, I did that. The tires are good. I'm taking it in on Monday so they can check it out, just to be safe. :)
  4. frosh
    frosh New Member
    35
    Virginia
    same here, never gave it a thought though ...
  5. frosh
    frosh New Member
    35
    Virginia
    call it strange sound, but are you sure it comes from the brakes? In "B", while coasting, the electrical motor reverses to a generator and yes it is noisier especially at higher speeds. I noticed it but took it as normal. I don't think the brakes would sound different, though...
    Did I get that right?
    frosh
  6. DeekoPete
    Wisconsin
    Well, I noticed it once when I hit the gas, too, but mainly using the brakes (not the "B" mode). It's nothing major, just a kind of gurgly-buzzing sound.
    As for the "Maintanence" icon, I just read the Nav manual and that's normal. Odd, but normal.
  7. Kizzy
    Kizzy Member
    111
    Los Angeles
    That is the brake actuator pump and it's normal. No worries. If you do a search on the forum you'll see that it's also a very common question from new owners.
    As for your Prius veering to the left, it's not uncommon for new cars to go slightly out of alignment during the cross-Pacific transit. Take it to your dealer and have them correct it. My brand-new Prius had an off-center steering wheel (the alignment was good, but the steering wheel was tilted slightly to the right when the car was tracking straight). I brought it back to the dealer the following week and they fixed it no questions asked. :)
  8. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    If the dealer aligns the car, they will most likely find it is aligned just fine. The most likely cause of a pull on a front wheel drive car is either a radial tire pull or tire conicity. Either of these cases can be corrected by crossing the front tire (swap right to left) or if necessary, reversing one tire on the rim. Radial pull is when one tire has a higher rolling resistance than the other creating higher drag on one wheel. Tire conicity is when the tires edges have slightly different diameters. A cutaway view of the tire would look cone shaped. No tires are perfect. If two tires are mounted with the cone shape facing in the same direction, it causes a pull. Reversig one tire causes the cones to canceleach other out and keep the car going straight.
  9. DeekoPete
    Wisconsin
    Interesting. I'll mention that when I take it in. It still pulls slightly to the left, but again, it's nothing major.
  10. richard schumacher
    7,666
    1,047
    United States
    Digressing for a moment: "B" should not be used in normal driving because it will decrease MPGs. It should only be used when going down a long downgrade to avoid riding the brakes.
  11. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Wrong. In "B" mode, in addition to the automatic "generator" braking at is on in "D" (and can only be turned "off" in "N"), "B" mode adds engine braking, spinning the engine to slow down the car with engine friction.
  12. frosh
    frosh New Member
    35
    Virginia
    R U sure?
    ever switched from "D" to "B" while coasting and watched the energy display? I was the opinion, "B" stands for battery mode, not additional friction...
    frosh
  13. frosh
    frosh New Member
    35
    Virginia
    I am utterly surprised, I always thought "B" should regenerate more energy. I even was reassured by thinking I heard the generator howl, but indeed its the engine...
    Thanks for your comments,
    and RTFM, frosh!
  14. richard schumacher
    7,666
    1,047
    United States
    Now you've got it :_> "B" = "engine Braking", not "Battery". It would not be very convenient to have to shift in order to get regeneration; most drivers would not bother.
  15. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
  16. Bob64
    1,540
    93
    Virginia
    while it allows you to regenerate SLIGHTLY MORE (10 amps vs the 5 amps of "drag" without your foot on the brake), you lose A LOT of energy with the engine drag. Btw: Your foot on the brakes lets you regenerate up to 60 amps.
  17. frosh
    frosh New Member
    35
    Virginia
    no wonder my mileage dropped after I've discovered "B" mode...
    great forum!
    frosh
  18. richard schumacher
    7,666
    1,047
    United States
    Ehh, maybe a few places in Virginia. More likely if he drives up into the hollers in West Virginia.
