Photo of blocked front Grill.
Discussion in 'Gen 2 Prius Main Forum' started by FishHawk, Jan 17, 2008.
  1. FishHawk
    FishHawk New Member
    176
    Can someone post a photo of their block grill ? I would like to see how you use the blocking material to block out the cold. Thanks FishHawk
  2. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
  4. bc104
    bc104 Junior Member
    57
    New York
    I have to wash my car then take pictures. I just installed it for the first time on Monday, 1/14. I used 3/4" gray pipe insulation, opened it, and mounted it behind the upper grill using zip ties. For the lower grille, I used gutter guard from Home Depot. Not the fence type; the plastic that is solid except for some small slots. Again, I used zip ties and it is behind the grill. Unfortunately I only had white lying around the garage, but it does come in brown also. It isn't nearly as noticeable.
  5. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    You should see mine, using a neon green pool noodle!!!
    I'm too embarrased to even post a pic. But hey, it was free, and my son is too young to notice his pool noodle is ~2ft shorter than it was :D
    Rob
  6. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I respect your frugality, but dark gray pipe insulation like a lot of us use is pretty cheap! Besides, your son will get older and eventually expect to have what's his. ;)
  7. bc104
    bc104 Junior Member
    57
    New York
    Ok, here's a pic!
  8. SpartanScott
    SpartanScott Michigan Member
    60
    Howell, Michigan
    Here are 2 more photos. Bought 4, 6' tubes (1") for a total cost of $3.50; each tube cut in half. No zip ties used and they have not budged. Enjoy
  9. gregzgurl
    gregzgurl New Member
    Is that safe?
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Yes. There are different opinions on how much should be blocked and at what temperature it should be removed. IMO if the fan hasn't started then it isn't too hot. I've kept the top blocked year round.
  11. JimN
    7,028
    1,117
    South Jersey
    bc104, excellent job.
  12. jiw395
    jiw395 New Member
    119
    NORTH WEST INDIANA
    It works for me, my mpg's went up instantly,like the minute I drove it after blocking off the intakes. It went from low 40's to mid to high 40's like 45/46, and it did that the very next time I drove it...
  13. bc104
    bc104 Junior Member
    57
    New York
    Thanks, JimN.
    My mileage has gone up as well, but I did several things at the same time. I blocked the grill, put a small piece of insulation on top of the engine (it doesn't touch the block or exhaust and is far away fromthe fan belt, just on top of the plastic), I'm driving a bit smoother (although I was already trying pretty hard not to use the gas too much) and I haven't used the heat. The begining of the tank was at 43 mpg average (about 20 miles used) and now I have 3 bars left at 51 mpg. I think I'm on to something here!
  14. dropkin
    dropkin Junior Member
    New York
    Do you all have SG's ? I have to contend with the "W" factor, so SG or not, it can't be something she has to think about. I'm in Westchester County, NY, and some morning's it's a solid 5 degrees. I'm getting about 45 mpg, but considering I usually get 60 in the summer, I was hoping there was a "low tech" and "set it and forget it" solution.
  15. patsparks
    10,664
    567
    Adelaide South Australia
    There is, move to a warmer climate.
  16. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
