Keeping the daylight GPS display
Discussion in 'Gen 2 Prius Main Forum' started by calpal, Jan 21, 2008.
  1. calpal
    calpal New Member
    52
    I do not like the night-time (dark) display when my headlights go on. How do I keep the day-light display when my headlights are on? Anybody know?
  2. ad78
    ad78 New Member
    120
    Rocky Hill, CT
    roll all the way up your panel light control located to your left side of steering wheel....
  3. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Honestly though, you need to be using the night time display. The daylight display is far too bright and it will affect your night vision.
    Try playing with the brightness and contrast settings for the night display to get it to where you're comfortable with it.
  4. jsnschmasn
    jsnschmasn New Member
    17
    St. Louis, MO USA
    There's an actual day-mode setting specifically for the GPS display. It will dim the display when you turn on the parking lights or headlights but it will maintain the same color theme. When the lights are on, press "display" and you'll see it. If the lights are off, the option disappears.
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Even aftermarket GPS have day (light background) and night (dark background) mode. My garmin announces the change at sunrise and sunset it is not an option.
  6. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    I often find I need to use my headlights when there is sufficient ambient light that I'd like to use the daytime illumination on the MFD. One of those times is when it's raining during daylight hours. Headlights should be on (believe it's in the CA vehicle code that they must be on if your wipers are on), but during the day, you want the daytime display of the MFD.
  7. Doc Willie
    1,717
    144
    Out there, somewhere
    Press the display button on the side of the MFD. If your headlights are on, a button on the screen should appear marked "Day Mode". Press that and you are set.
    There is another setting that allows you to adjust the brightness of the display, I think on the same screen.
  8. SW03ES
    2,480
    176
    Gaithersburg, MD
    Then just rotate the rheostat (the knob that dims the instrument panel illumination) up until it clicks and it'll automatically jump to day mode.
  9. qbee42
    3,081
    This is the situation where you should use the dimmer wheel in the full up position. This will brighten the speedometer display to the daylight setting, and cause the MFD to use the daylight setting.
    If you want the MFD to display the daylight setting at night, use the daylight mode button on the MFD screen. This way the speedometer display dims as it should at night.
  10. priusenvy
    1,765
    Silicon Valley, CA
    I do. Your post assumed the OP had his headlights on because it was dark. I was pointing out that there are conditions other than darkness where you want the headlights on, and under those conditions one might want the daytime display.
