Anyone Gone Wireless N?
Discussion in 'Fred's House of Pancakes' started by boulder_bum, Jan 21, 2008.
  1. boulder_bum
    boulder_bum Senior Member
    1,371
    Castle Rock, CO
    If so, how's the throughput, and have you used brand X's router with brand Y's device? How well does everything play together?
  2. Fibb222
    Fibb222 New Member
    1,499
    99
    I went with Dlink DIR-655 and the associated Dlink adapter. I don't think the speed is all that much greater, and the router needs to be reset occasionally where I didn't have to do that with the old one. Hopefully newer firmware will address that problem. I hoped it would help me transfer large files to my living room machine but it's still not nearly what I need. File transfers don't complete before the single drops out so they don't complete. Dlink support wasn't any help although we changed a number of settings. I'm just going to get a 6 Gb thumb drive as soon as the price drops.
  3. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    I couldn't punch a decent wireless signal through the complex set of obstacles in my mom's house using G. The signal was simply too weak. N easily solved that problem.
    It works fine for her. My notebook likes it too. Not sure of the speed, but there certainly hasn't been any reason whatsoever to complain.
    Linksys (the one with the funky third antenna) is the router I used for that along with a USB adapter on her rather old non-wireless computer.
  4. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    Thats just D-Link for you. They are complete junk. You'll always have to reset them every day.
    I've seen and researched N, but I dont have it in my house. I'm not going to until IEEE makes it a standard. Because until then, any (Pre)N hardware may become inoperable in a few months. It happened to (Pre)G. IEEE changed the specs of G right before they put it out, making all (Pre)G hardware trash. IEEE wont do it for probably another year or so, but until then, my internet connection is only 12mbps, lan is only 100megs, MIMO G is 108, so that works for me. I'll definatly be getting it though.
  5. Alric
    Alric New Member
    1,526
    87
  6. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
  7. hill
    8,898
    We have a wireless N bridge into our home network that up & downloads over 2megs per second and the bridge keeps up with it easily.
  8. Betelgeuse
    1,460
    24
    New York, NY, USA
    But those data rates are well within what G should be able to give you (i.e. 54 Mbit/s ~ 6 MBytes/s). One of Pogue's points back in April (when he wrote the NY Times article) was that the (Pre)N routers were giving data rates well below what they should be able to give. I don't know if this has been fixed yet, but it's interesting to consider.
    Another thing to realize is that almost no one is actually going to be able to take advantage of those data rates to the "outside world." In other words, if you have a wireless router capable of 300 Mbit/sec and you have a 12 Mbit/sec connection (i.e. pretty much the top end of cable connections), it's obvious where the bottleneck is going to be; the N technology is pretty much only useful at this point if you're going to be transferring files between your computers in your house (i.e. NOT for the connection to the outside world).
  9. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I'm staying away until they finalize the spec. I really don't see the need for more range or higher speed. I really don't see how N gets longer range when using the same frequency as b/g. Maybe it transmits at a higher power level or they have a higher gain antenna? I really have not looked into that part. As far as speed goes it wont make your internet any faster. It will just make transferring files form one PC to the next faster.
    I just upgraded my Linksys WAP11 802.11b access point ( installed hacked dlink firmware ;) ) to a Linksys WRT54GL 802.11b/g and upgraded it to the Tomato firmware yesterday :D. The only reason that I upgraded was because I wanted a little faster large file transfer speeds to my Prius and laptop computers. If I need to extend the range the Tomato firmware will allow for more transmit power and if needed I can add some higher gain antenna.
    If you want N I would personally wait until the standard is finalized so you wont have any hardware that will not work with each other.
  10. boulder_bum
    1,371
    Castle Rock, CO
    The difference, as I understand it, is that N uses multiple inputs/outputs (MIMO), which usually means three antennas instead of one.
    I didn't before, but now that I'm going to be streaming HD content and multi-gig movie files across the network, it's all of a sudden become somewhat compelling.
    I too would LIKE to wait for the standard to be ratified, but, gee whiz, they've had devices since 2006 and were SUPPOSED to ratify it in 2007! Now they're saying 2009?!?
    I'm still not sure I'll get an N setup, but I think more and more people will develop the need for a faster-than-G network as digital videos and HD streams become more popular. It's about time we start moving forward with wireless technology.
  11. n8kwx
    n8kwx Member
    236
    Arlington Heights, IL - NW Chicago Suburb
    Welcome to the world of computer specs!
    The 54 Mbit/s rate is the maximum raw data rate of the radio.
    As far as I know WiFi radios are half-duplex. Which means that they don't transmit and receive at the same time. So the sustained throughput is going to be much less. The latencies of radio implementations are typically much higher than a wired connection. This also kills throughput compared to a wired link.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    I had D-Link DSL G604T and it was crap!
    I had to reset it several times a day.
    I installed a Nettcom modem and wireless router about a month ago and haven't touched it since.
    As long as the modem has been working the wireless hasn't been a problem. I can use my laptop in the back of my back yard about 30 metres from the router and through about 3/4 of my house with excelent signal strength. Never had an issue with speed, I have used skype along side yahoo video conferencing with no issues over wifi. My son downloads videos with no issues on the other desktop.
    PC to PC over the wifi is faster than the network where I work.
  13. Betelgeuse
    1,460
    24
    New York, NY, USA
    True. Overhead can (and does!) reduce the throughput. However, the point of my post is still valid; the maximum throughput of an 802.11g connection is so much higher than 2 MB/s that the hit that it takes from overhead doesn't make any real difference. Pogue's point was that many of the (Pre)n routers were way below where they should be, even including overhead.
    I don't know about the duplex-icities of WiFi; I have no reason to doubt that you're right. However, this isn't a big deal for the average home user. Most of the traffic for a typical home user is downstream, anyway, which is why most people don't care that their DSL connections are asymmetric.
  14. Godiva
    Godiva AmeriKan Citizen
    10,339
  15. boulder_bum
    1,371
    Castle Rock, CO
    FYI
    Wireless G maximum speed = 54 Mbps (megaBITS per second).
    8 Mbps ~= 1 MBps (megaBYTES per second)
    ...so 54 Mbps can transfer a theoretical maximum of ~6.7 MB of data a second. However, typical throughput is 23 Mbps or ~2.9 MB.
    Wireless N is supposed to be 248 Mbps theoretical, 74 Mbps actual, or about 9.25 MB/sec, though I've seen reviews of the DIR-655 claim real-world speeds of over 100 Mbps at short range (10 feet).
