Nav System Question
Discussion in 'Gen 2 Prius Audio and Electronics' started by DeekoPete, Jan 22, 2008.
  1. DeekoPete
    DeekoPete New Member
    Wisconsin
    Ok, I drove around a bit today using the nav system and it's pretty slick. However, I did end up driving a bit out of my way (I'll admit it, I didn't know where the hell I was, I was entering locations just for fun - I'm odd that way) and used the "Home" function to find a direct route home. Once I realized where I was, I wanted to continue to Best Buy and listen to some music, but I couldn't figure out how to tell the Nav system that I was finished using it.
    How do you shut the nav system off when it's giving you a route?
    :) Thanks in advance!
  2. jrfaris
    jrfaris Member
    352
    Windward Oahu
    The menu button, top right, allows you to suspend guidance. You can also hit the route icon on the bottom of the map screen and delete all your destinations.
  3. Aviator
    Aviator Junior Member
    33
    Harlingen, Texas
    Or, you can use the voice command and say, "Suspend guidance."
  4. DeekoPete
    Wisconsin
    Awesome. Thanks for the help! :)
  5. qbee42
    3,082
    Which may suspend guidance, or may say: "showing ski resort icons".
  6. Aviator
    33
    Harlingen, Texas
    All shucks, it works for me :)
  7. qbee42
    3,082
    Works for me too, mostly. Jill gets a little confused sometimes, but mostly she does okay.
