Prius starting problem! Help!
Discussion in 'Gen 2 Prius Main Forum' started by lp2, Jan 23, 2008.
  1. lp2
    lp2 Junior Member
    I brought a Prius in March 2007. I have been happy with the car. Lately it started to have intermittent starting problem.
    On 1/21/2008, the car completely refused to start. Here is a video I took that day when I tried to start the car: Picasa Web Albums - Alan - Prius problem
    Eventually I have to call a towing company to tow my car to the dealer. The tow guy jump started the car.
    The dealer found nothing wrong with it, give the car back to me and charged me for the towing service.
    Dealer claims it's not a battery issue since they load checked the aux battery.
    What should I do next? Help!
  2. qbee42
    3,076
    Try to figure out what you left on in the car. This problem is normally caused by leaving on a light or the headlamps.
  3. lp2
    lp2 Junior Member
    No light, cause I don't use them.
    No headlamp neither.
    Armed the car every night.
    Dim interior light, no MFD, flashing instructment panel are usually the sign the car wont' start.
    I don't think the battery is drained.
    There are occassions where it won't start the first time, but after a couple of try, it will eventually start.
  4. qbee42
    3,076
    Sounds like a classic 12V battery problem. Make sure the terminals are clean and the connections sound. Do you drive far enough to make sure the 12V battery gets charged? If not, leave your Prius running for a few hours to make sure the battery is charged. It doesn't charge very fast from the built-in charger.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i have a 12v problem. it doesn't look like a 12v problem. the huge triangle shows up when you run the car down.. also.. things don't "pop up" that easy.. it takes time to load.. and then eventually triggers the traction battery which helps the system load up.
    i've only seen blinking like that after hooking up hooking up the car charger directly to the car. it takes a few tries before the car realized it was only a voltage irregularity and eventually boots up. *shrug*
  6. richard schumacher
    7,664
    1,043
    United States
    What does that mean, exactly?
    Summarizing common causes: 12V battery defective, or failing because it was previously drained; left a door or the hatch not completely closed overnight; poor connection at the 12V battery terminals; charging system problem (not very common); aftermarket or third-party electronics defective or incorrectly installed.
  7. lp2
    lp2 Junior Member
    I push the little black button on the handle everytime I exit the car.
    I don't have any third-party electronics installed.
  8. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    There have been a few cases where the -ve battery cable has corroded where it is bolted to the body in the right rear. Easy to check, easy to fix if that's it.
    I DO NOT believe the dealer knows how to properly check a battery. I've only seen a few who do. Get a VOM or voltmeter and check it yourself. Before you start the car one morning, check the voltage on the 12V boost terminal under the hood (it's the same point as the battery). You should see AT LEAST 11.8V there, and a normal reading would be 12.5V. If it's down 2V or so you've got a bad battery (dead cell).
  9. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    You might also have an intermittant brake light switch concern. If the ECU doesn't see a brake signal (stepping on the pedal) it will not activate the HV system. When the condition is occuring, does it turn on the main dash lights, but not give a ready light?
  10. removeum
    removeum Member
    407
    El Paso, TX
    :cool: Were you holding the break all the way in?
  11. lp2
    lp2 Junior Member
    Can you provide instruction on how to check it?
    The main dash lights is on and flashing. No ready light.
    Yes.
    Other symptoms are dimmed dome light, no power to MFD, and can't power down.
  12. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Sounds like the dealer is clueless or doesn't give two s***s. I'm not sure how comfortable you are working on cars.
    In the rear hatch area, near the passenger side tailight, on the interior side near the hatch floor you will see a trim cover. Remove the tray cover first, they carefully pull the trim cover away. Also take out the tray itself.
    You should be able to see the motorcycle-sized 12 vdc battery. The pos post is covered by this huge red plastic cover, the neg post is bare. Pos post is towards the front of the car, neg post to the rear of the car
    You will notice a tiny cable - more like a wire - going from the neg post to the unitbody. The ring terminal is secured by a bolt. I have noticed corrosion on the bolt threads, which you can't see unless you back the bolt out. So I'm in the habit of backing out that bolt and snugging it back up every 6 months
    To check the battery voltage you'll need a DMM (Digital Multi Meter) set on DC volts. That huge red plastic cover is a royal PITA to get off, I buggered mine up when I tried to pry it off.
    The proper voltage for a 100% theoretical charge is 12.8-13.2 vdc. You'll need over 12 vdc to boot up the car. If the battery is chronically undercharged, it won't have enough capacity to run the brake boost pump and coolant transfer pump, both of which can contribute to a momentary 40 amp draw
    If you feel comfortable removing the hold down clamp and vent tube, I strongly encourage you to remove the battery from the car and properly charge it. The Toyota pdi recommends an automatic battery charger set to 10 amp charge rate
    If the battery is badly undercharged, you may need to leave it charging overnight. Once the automatic battery charger indicates full charge, disconnect the charger clamps and leave the battery sitting at least 4 hours, preferably 24 hours, not hooked up to anything.
    Then recheck the voltage. A reading of 12.8 and higher is very good, the battery should be ready to work. A reading of 12.4 and under would indicate a bad battery.
    As an example, I use VDC Battery Minder float chargers on all my equipment, and the float chargers are always plugged in. If I do a 24 hour resting voltage check, all my batterys will indicate 13.01-13.18 vdc
    If the battery indicates full charge, put it back in using the reverse order of removal. Have the fob handy as most likely the alarm will go off once the neg cable is hooked up. My alarm has gone off every time I've put the battery back in
    If the battery now works ok, maybe check the voltage a week later just to verify. As David Beale mentioned, you can check using the underhood jump point instead of taking apart the rear hatch area. However, if after a few days the car is dead, you're going to have to check for parasitic loads
    I'm still surprised the dealer couldn't check for parasitic loads. Again, I'm afraid you'll have to do this yourself
  13. lp2
    lp2 Junior Member
    Technician relied on the computer so much if the computer tell them there is no problem, he believe the car is fine. But if the 12v can't power up the computer, the computer can't store the code correct?
    I am going to check the voltage next time it happen. But I am pretty sure it will read low as indicated by the dimmed dome light and weak horn alarm everytime.
    What I don't understand is why sometime it will start after 2 or 3 try?
    Is my battery flaky that sometime it just does not have enough amp?
  14. satwood
    satwood Member
    107
    Webster, MA, New England, USA
    2014 Prius v wagon
    We're all assuming this really is a battery problem. However, if you watch his video the dash lights are fully bright and there is no sign of a struggle for the lights to stay bright. I don't think it was due to a dead battery. I think there could be another intermittent connection involving the computer or the other HSD systems that gave the indication of a fault. The vibration of the towing and the electrical jolt of jump starting the car may have temporarily cleared the problem. That's just pure speculation on my part.
    Steve
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    I don't know what's wrong with the forum, but I can't seem to edit my post. Please read the following important safety notice:
    Remember that lead acid batteries are DANGEROUS if improperly handled. In normal use they give off hydrogen gas, which is the reason for the vent tube. Batteries also have very high short circuit amperage, say from a dropped wrench across the posts. If the battery explodes, you could be blinded from the acid
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    He did post that the dome light is dim
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    It sounds like you are on your own. It seems as if mechanics no longer rely on common sense
    A poor connection or a weak battery can cause all sort of problems with electronics. Once the voltage sags below threshold or gate values, the system may behave in unexpected ways
    Around 12 years ago a Boeing 767 had numerous in-flight problems with the autopilot and the display screens going blank, on a flight from Schiphol, Amsterdam to the US. The problems became severe
    They declared an emergency and landed at Logan. The investigation revealed a loose battery shunt tie-bar due to improper maintenance
    ASN Aircraft accident description Boeing 767-31AER PH-MCH - Boston-Logan International Airport, MA (BOS)
  18. richard schumacher
    7,664
    1,043
    United States
    Take it to a different dealer. This one either doesn't know enough or doesn't care.
  19. Bear68
    Bear68 Member
    373
    72
    Sure sounds like a 12v system issue.... I would recommend a couple of simple checks.
    1) check the 12v battery itself. The terminals and the ground wire. be sure they are all tight and clean.
    2) check the 12v connection under the hood. The same one you would use if you were going to jump start the car. Make sure it is tight and clean. (saw one from the body shop with that wire loose, caused all sorts of goofy symptoms)
    3) FIND A REPUTABLE DEALER!!! If your Prius is still under 3/36 warranty, camp out in the service manager's office and be as politely firm and direct as possible. You might also want to check your owner's manual for the 800-Toyota number and give that a call. You paid for the car and te warranty. YOU DESERVE RESPECT AND A PROPERLY REPAIRED CAR!!
  20. lp2
    lp2 Junior Member
    They finally found the problem! They said it was the 12v battery. DUH!
    Here is quick recap:
    Mon: Car won't start. Towed it to dealer.
    Tue: Service Advsior said nothing is wrong with my car. The technician wants to keep it for another day. I told them to do a load test on the 12v battery.
    Wed: Got a call from the Service Advisor in the morning saying they can't find anything wrong with the car and it's ready for pick up. At this point I escalated the case to the Service Manager and Toyota Customer Care. I arrived at the dealer later that day and shown the video to Service Manager. Service Manager showed me the 12v battery passed the load test. Service Manager called a field technician and described the problem. Field technician suggested to do a 15 minutes battery test on it.
    Thur: Service Advisor said they found a bad cell in the 12v battery.
    Thank you for everyone help. I am a happy prius driver again!
