Windshield Wiper Blades
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mabelair, Dec 17, 2007.
  1. mabelair
    mabelair New Member
    96
    Ottawa, ON
    All right, so I picked up my Prius yesterday, and sure enough, we have a huge snowstorm that dumps 30cms of snow in the space of a day. Aside from all season tires simply not being up to the task, I had a number of issues with the windshield wiper blades, as they kept streaking, and generally made a mess of the snow on the windshield.
    Luckily, when the car is driving faster than 20 km/h, it's not an issue since the car is so aerodynamic, but for those of you in colder climes, do you have any suggestions for good winter wiper blades?
    I'd appreciate any info you could provide.
    Thanks,
    MAB
  2. Tideland Prius
    16,539
    Unfortunately, no lol. But I'm sure MarkDerail, David Beale, Kinghuang, Jayman, Sarge and so forth can chime in. I've managed to get away with the standard blades but I don't think I can this year esp. if they're forecasting colder + snowier across the entire country.
    Looking forward to your advices for snow blades!
  3. Devil's Advocate
    922
    Las Vegas, Nevada
    I'd recommend the new constant pressure blades. I think Michellin and Bosch both have blades. The use spring metal to keep constant pressure over the whole blade instead of the spring and bridge design. Plus no gaps for snow to collect. I believe the Bosch version go under the name Icon.
  4. shottesbrooke
    shottesbrooke New Member
    Bosch Ikon
    The Bosch Ikons/Icons are great - I've got a set on my 2006 - you can slightly upsize the driver's side blade too, if you like, to 28" from the stock 26". The provide a very clean sweep and minimal noise, and they give the car a cleaner look to boot. There are two fitments - the Prius (I think, you should confirm) takes type 'A'.
  5. Devil's Advocate
    922
    Las Vegas, Nevada
    Also, If you want to replace the rear wiper with anything than something from Toyota, you have to replace the entire arm. There are thereads in PC that tell you where to get a new arm. It's not cheap, but you can then put any standard blade on the arm, and a larger sized blade too!
  6. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    That's good to know re the driver's side. Is there enough room to increase the passenger's side too from the stock size?
  7. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I just ordered the RainX Latitude wipers. I'm waiting for them to arrive. I'll let you know how/if I like them once I get them on.
  8. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    What's "Snow?"
  9. JaviNOS
    JaviNOS Mod Freak
    150
    Puerto Rico
    I just installed Bosch Icon's about a week ago... Its always raining here in PR! :mad:... They work great. Icons are also stock blades for Civics Si and some BMWs from what I've seen so far... So they must be good. My 2 cents:D
  10. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    From previous posts, "winter blades" from Trico are:
    26" -P/N 37-260 (drivers side)
    18" -P/N 37-180 (passenger side)
    These are the metal framed rubber covered types.
    The dealer only had 24" and 18" in the "Toyota" part. In fact, he couldn't even find a listing for the Prius, and those he found were "substitutes". Not very impressive!
    Canadian Tire didn't have 26" (though they did have 28"), so I walked away. OK, I ran away screaming, but that's just me and Canadian Tire!
    So I haven't purchased any yet. I also haven't needed any yet as we don't usually get heavy snowfalls here. We just get a few cms. at a time, it just doesn't melt until April!
  11. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    what's the inch size for the passenger side? I know the driver requires 26 inches :)
  12. koa
    koa Active Member
    980
    45
    Hawaii
  13. koa
    koa Active Member
    980
    45
    Hawaii
  14. jbdan
    jbdan New Member
    51
    ATL GA
    18" :) Bosch Icon replacement is 418A. For driver side it's 426A although 428A will work as well.
  15. dogfriend
    7,512
    1,190
    Carmichael, CA
    Its a fluffy frozen form of water. Rarely if ever seen in Hayward. If you want to experience it first hand, I recommend you go to Tahoe this weekend. ;)
  16. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    lol you've read my mind :)
    wow shipping and handling came to 60 bucks! but its the fastest express USPS shipping, totalling 100 bucks, oh man i hope these blades are worth it, since mine right now are leaving mad streaks and are making that creak noise
    everything on top came to 70 bucks , werid
  17. patsparks
    10,664
    567
    Adelaide South Australia
  18. jbdan
    jbdan New Member
    51
    ATL GA
    That is a little pricey, but I do not think they will dissapoint and you should get what you want! AutoZone (well it's in the Southeast) has a sale on icons $18.99 a pop all sizes. Not bad. Any of the new fangled blades (rain-x latitude/bosch icons/some other brand I forget) are a great improvement over standard metal blades. They are all super quiet. Let us know how they work for ya!
  19. Doc Willie
    1,717
    144
    Out there, somewhere
    It's the length of yer . . . never mind.
  20. patsparks
    10,664
    567
    little toe?
