Dash Board blackout
Discussion in 'Gen 2 Prius Technical Discussion' started by tony99, Jan 24, 2008.
  1. tony99
    tony99 New Member
    hi
    My toyota Prius 2004 dash board black out. No km or speedometer show on screen. MFD is working. I disconnect battery and replug it start working and on next start have same problem. I talk to my friend he think my screen need to replace any new sugestion or solution.
  2. Tideland Prius
    16,602
    Are you sure the dimmer switch isn't all the way down??
    If it isn't, then yeah you probably have a faulty screen or wire or something.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Are you completely sure that the rheostat isn't cranked all the way down? The dinner switch is to the left of the steering wheel on the dash behind the headlights stalk.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Third moderator in a row...your dimmer is turned to the "off" position.
  5. tony99
    tony99 New Member
    sorry guy it is not a switch problem. If it is a switch problem then why start working as I disconnect battery and replug. any other suggestion.
  6. Tideland Prius
    16,602
    hmm... this looks like a job for galaxee's DH.
    try PMing her. (Galaxee that is)
  7. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Check for Something Blocking your Projector Cover
    I had this problem last year when car park attendant's ticket slid down my dash and covered the clear projector cover (that's when I discovered my display was actually a mirror reflection of a projected image). I removed the ticket and it was lights on again.
    I hope your problem is as easy to fix.
  8. John in LB
    John in LB Life is good
    399
    27
    Orange County
    Where is the Lunch switch? - I am hungry :D
  9. Vincent
    641
    31
    South Florida
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Funny typo joke haha.
  11. Doc Willie
    1,717
    144
    Out there, somewhere
    Prius Nav Voice Command System Voice: "Beep. Food Replicator functions are not available on this screen."
  12. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    last evening I had an envelope slide across the dash and cover the speedometer reflection which momentarily blacked out the speed. Since our speed is but a reflection, it very well could be something has fallen into the opening and is not allowing your display to "display" !!
    :D
  13. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    The blocked mirror hypothesis also don't seem to fit the disconnecting the battery makes it work again for 1 cycle symptom...
    Rob
  14. tony99
    tony99 New Member
    HI Guy
    Thanks finally trip to mechanic make it work. They replace my console and it work perfect and cost me $500
    thanks
  15. Priusaurus110
    Priusaurus110 Junior Member
    31
    Monument, CO
    Tony99: just for future reference, what did the mechanic find as the cause of your problem?
