Key Question
Discussion in 'Newbie Forum' started by Mississippi, Jan 28, 2008.
  1. Mississippi
    Mississippi New Owner
    Deep South
    I just bought a prius on saturday... it was used... they only had one key/remote to give me.
    My car has the smart key option... the remote has a silver toyota logo on the back....
    my questions are....
    1)can you use the small key inside the remote to get inside the car if the remote battery fails?
    2) how much will it cost me to get a new key and smart remote from toyota?
    3) if i buy a smart key and remote on ebay, how do i get the little key inside the remote cut so it will work my car? how do i program the remote?
    Thanks in advance for any input.:confused:
  2. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    >> yes. That is the whole point of having it.
    >> I would say at least $250 if you still have one remote. If you lost the one you have, it will be at least $400 since they would need to find the code that is unique to your Prius. So get another while you still got one.
    >> Cutting is the key is no different from any other home key. Any key smith can do it, I guess. For programming the remote, you need to go to a dealer. Make sure you get a remote that has never been programmed before from eBay. Less surprises/problems.
  3. Mississippi
    Deep South
    Do you know how many of the keys come with the car when the cars are brand new?
  4. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
  5. Thump553
    Thump553 Junior Member
    CT
    2020 Prius Prime
    We just bought a new Prius. On our test drive the salesman said it cost $300 to get a replacement smartkey. When we closed the deal on the car, he said $400.
    Hopefully I will never have to find out.
  6. Mississippi
    Deep South
    [ a smart key and remote on ebay, how do i get the little key inside the remot
    >> Cutting is the key is no different from any other home key. Any key smith can do it, I guess. For programming the remote, you need to go to a dealer. Make sure you get a remote that has never been programmed before from eBay. Less surprises/problems.[/QUOTE]
    I called a dealerships parts department... a guy there said the key was laser cut, and had to be done somewhere else.. do you know if that is true?
    also.. what is involved in programming a new remote?
    If i buy on ebay, will any dealership program the remote and have the key cut for me?
  7. qbee42
    3,074
    If i buy on ebay, will any dealership program the remote and have the key cut for me?[/quote]
    No, it's cut like any other key. Be careful of SKS fobs from eBay: some work, and some don't. You have to make sure you get one that is correct for your type of Prius.
