LED inside light's
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Flying White Dutchman, Jan 31, 2008.
  1. Flying White Dutchman
    4,376
    313
    almost finished my LED inside lighting
  2. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    Where did you get the LED lights?
  3. Flying White Dutchman
    4,376
    313
    from a car shop in town!
    i life in the EU and these are italyen made! 11,5 for the 6 led T11
    and 5,75 for a set (2) of the T10 small led for the reading lights.
    these are in dollars i converted them from the euro-dollar.
    normally in the door there are T10 to but i dont think the light is strong anough so i am going to custom fit a T11 in there with the 6 leds just like the on in the cargo.
  4. Dngrsone
    189
    Thank you... I will hit the local car parts vendor and see what they have.
  5. Tideland Prius
    16,648
    wow!
    are they as blue as they look in the picture or are they white?
    Maybe you should send some over lol. Beats buying the chinese ones off ebay!
  6. Flying White Dutchman
    4,376
    313
    there white realy white
    onlye i think the camera realy makes it look like this
    edit
    some pictures from the cargo light fitted
    and a bigger picture from the store packing so you people can look for these in the us
    edit
    o the bigger picture wont upload! ist to big res.
    edit
    found some pictures from .it
    http://www.tecnosoundsanremo.it/images/lam_58435_104_1_500_p.jpg
    the brand is "lampa" from italy
    can not find a website yet buth here is one TecnosoundSanremo.it: RML/6CW Race Micro Led T10 a 6Led Crystal White...
    edit
    got it
    Exterior interior accessories for cars, car tuning, bike accessory, motorsport accessories, automotive parts, vendita accessori per auto, autoricambi, accessori biciclette e camion
    edit
    and here a direct link to the led lights
    Accessories for cars, car tuning, spare parts, bike and moto accessories
  7. diversified
    diversified Junior Member
    70
    State College PA
    I attached some pictures of my interior LEDS. They give the car a whole differant look.
  8. Flying White Dutchman
    4,376
    313
  9. Dngrsone
    189
    Thanks, guys. I can't believe that they would use incandescent lamps inside and outside on an electric vehicle... :confused:
  10. Flying White Dutchman
    4,376
    313
    brake lights are led:D thats it!
  11. Dngrsone
    189
    Are they? I'll have to take a closer look.
    I mean, it isn't that expensive for LED bulbs, and they last longer and have much less current draw...
  12. siliconhybrid
    siliconhybrid Member
    121
    Bay Area California
    I am so confused right now.
    Can anyone list what type of LED is for what light? i.e:
    Cargo light (trunk area) = Type?
    Front Dome light Left & Right = Type?
    Front Dome light Center = Type?
    Courtesy Door light = Type?
    Rear Dome light = Type?
    Vanity (behind visor) light = Type?
    That would help a lot.
    Thank You
  13. Tideland Prius
    16,648
    Cargo = DE3022
    Front Dome/Maplights = 194/168
    Courtesy = 194/168
    Rear dome = DE3175
    Vanity.. don't know but I believe it's 168 too.
  14. Tideland Prius
    16,648
    Thanks!
    I only see T3 and T5. I don't see T10
  15. darelldd
    6,059
    389
    Northern CA
    This isn't an electric vehicle. Electric Vehicles don't use gasoline. Though I agree... drives me nuts that they use incandescents where LEDs would be far superior. I'm glad that at least the brakes are LED. The entire interior of all my cars is LED - but they sure didn't come that way.
    Automotive lighting
    I spent a bit of time making an accurate list here:
    Bulbs
  16. Dngrsone
    189
    Electrically powered, then. I was thinking (at the time of my prior post) of my NEV, which has the same problem.
  17. patsparks
    10,664
    569
    Adelaide South Australia
    Not electrically powered either. Electronic controlled and variable drive train. Most of the power goes from the internal combustion engine to the road via a gear train, some travels via generators, motors inverter and batteries.
    The reason the brake lights are LEDs is for the faster response times (and space age look).
    LEDs are virtually instant on where an incandescent element takes a fraction of a second to heat to white hot. This quicker response time means following drivers have slightly more warning of a braking event.
    I suspect cost was a factor in the decision to use incandescent lights.
    Oh the glove-box light is LED also. Same reason USA has the worlds cheapest Prius' but no height adjustment of the drivers seat.
  18. siliconhybrid
    121
    Bay Area California
    Any comment on this ebay item?
    This is a 12 LED Type T-10 (for map light and courtesy light)
    What is a typical 12 LED power consumption? I am afraid it draws too much power. I believe 5W is the max.
    12 LED ebay link
    And here is 9-LED Type 3022 for Trunk & Vanity light
  19. darelldd
    6,059
    389
    Northern CA
    12 5mm LEDs cannot dissipate anywhere NEAR 5W. In fact it would be tough to get 1W for longer than a few seconds. My comment: It'll be as dim as most of the other 5mm-based LED products.
  20. siliconhybrid
    121
    Bay Area California
    Thanks Darell
    where could one buy super bright white LEDs (T-10 and 3022)
    I dont mind on the price.
