personal record 3,9L/100km
Discussion in 'Gen 2 Prius Fuel Economy' started by Flying White Dutchman, Feb 2, 2008.
  1. Flying White Dutchman
    4,376
    313
    today drove my firts 35km's
    and..... already 3,9L/100Km thats 60,3mpg US or 72,43 imp. mpg
    look at pic
  2. Tideland Prius
    16,547
    ahh... 33 kms haha. I did it over an entire tank :p:p.
    Keep it up!
  3. Flying White Dutchman
    4,376
    313
    ok
    let the games begin:cool:
    edit
    o
    and dit you check the temp.?
    3 celsius and 37.4 F
    thats realy low
  4. Flying White Dutchman
    4,376
    313
    o
    thats realy low
  5. patsparks
    10,664
    567
    Adelaide South Australia
    Keep it going now and make us all proud.
  6. Flying White Dutchman
    4,376
    313
    i think its a best ever
    i turn the heating to MAX COLD and its was freezing inside the car:Da
    and i dit not go past 50kmph
    and ofcourse there was a lot of traffic jam about 33km long
    behind me:p
  7. Tideland Prius
    16,547
    oh fine haha... my lowest at 36km was 3.5L/100km :p you can find my picture somewhere on PriusChat and no it wasn't at 3°C though so good job!
    MAX COLD? Doesn't that run the A/C compressor?? I'd leave it at 18.5°C or just leave it off altogether (unless the windows fog up)
  8. Flying White Dutchman
    4,376
    313
    max cold and the ac off
    then you tell te car not too heat the car and not use the ac
  9. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    With the temperature in northern Indiana at ~25F yesterday(windows cracked to prevent fogging and heat set to lowest and no fan), I averaged 92.2 mpg over 12.9 miles on country roads. I ended up with 73.3 mpg over 45.1 miles for the day.
  10. Flying White Dutchman
    4,376
    313
    92,2?? on a prius..
    is that posiible?
  11. diamondlarry
    559
    Elkhart, IN
    I have gotten over 100 during the summer months. This is verified by my Scanguage2. Before you ask if it's properly calibrated, there has been more than one occasion where the SG2 and the fuel pump at the station were within .002 gallons.
  12. Flying White Dutchman
    4,376
    313
    howe dit you to this?
    add battery's?
  13. diamondlarry
    559
    Elkhart, IN
    I gently pulse up to 30-35 mph and glide(no arrows on the energy screen) down to ~20 mph. I generally try to plan my trips so that I'm not concerned with the time it takes. Even though I live in a rural area, I still have to be considerate of other traffic so these numbers aren't always possible. There is another trip that I take on a regular basis that is 7.0 miles that is from my bank to my home and, on numerous occasions, I have maintained 120+ mpg. In fact, my record is 159 mpg. On one occasion, I force-charged the pack to 8 green bars and was able to maintain 227 mpg on a 6.4 mile trip between my regular gas station and home. By the time I got home, the battery was still at 6 bars. This was a one-time thing because, overall, it really only makes for a high number and essentially takes the same amount of fuel since the car isn't moving while force-charging the battery. I just wanted to see what the car was capable of. And, to answer your question about extra batteries, no, the car is completely stock.
  14. Flying White Dutchman
    4,376
    313
    ok
    so you drive EV mode a lot?
  15. diamondlarry
    559
    Elkhart, IN
    I actually try to avoid EV except for extending a glide that didn't make it to a stop sign or similar situation. T try to glide with the engine off and no arrows as much as possible.
  16. The Tramp
    The Tramp Italian Prius Expert
    375
    51
    Turin, Italy
    2020 Prius PHV
    Somewhare there is a picture of my display showing 3,3 l*100 km over 1000 km - I still had 1/2 tank to go. :D
    Keep working on it. ;)
    Today I could have taken a pictire of the display showing 0,4 l*100 km over 45 km - but it was mostly downhill. :lol:
  17. Flying White Dutchman
    4,376
    313
    eu got bigger tyres:D:p
    195/55/16
  18. The Tramp
    375
    51
    Turin, Italy
    2020 Prius PHV
    I'm EU. :p
  19. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The 195/55R16 is wider than the 185/65R15, but their diameters are the same.
    Ken@Japan
  20. Flying White Dutchman
    4,376
    313
    wider means more ground contact.?!
    @ tramp
    mmm wel you life a hot climate;)
    :p
