iPhone Mounting Options - what's best?
Discussion in 'Gen 2 Prius Audio and Electronics' started by terramar, Oct 30, 2007.
  1. OlsonBW
    OlsonBW New Member
    254
    Re: iPhone Mounting Options - what's best?
    The iPhone should work like other phones with bluetooth.
    Mine isn't an iPhone ... yet, but when a call comes in my phone automatically picks it up and the MFD pauses my iPod. Then when you hang up your music starts playing again (assuming you had music playing to begin with).
    Your iPhone should work like that.
  2. nicholfd
    nicholfd Junior Member
    Indiana
    What interface do you have to control your iPod?
  3. BellBoy
    BellBoy Member
    223
    Guys...my iPhone LOVES this solution. I have it plugged in to the AC under the glove-box.
    I bought the version previous to this so I don't know EXACTLY how the iPhone would react, but it works great for me. The iPhone will complain about it not working with the iPhone, but the message can be closed or it closes by itself after a few seconds. The bluetooth doesn't have a problem with the iPhone and it works great as it's within reach for a quick dial.
    YMMV. :)
  4. Craig K
    Craig K New Member
    17
    Connecticut
    Howdy:
    I implemented the solution that Ad78 suggested and it works great with my iPhone. I get the "nag screen" about the airplane mode, but a simple "just say no" makes it go away and I am off and running. I do hear a very faint high pitch whine that others have mentioned so I may try to get the filter. Anyway you shake it, this is an awesome set up. I thought about the DICE system but then you are still left with only one screen to see everything. This way you have two, the MDF for all the car functions and the iPhone for music. Beauty!
    Craig
  5. ad78
    ad78 New Member
    120
    Rocky Hill, CT
    good to hear craig:)
    @bellboy - how do you close your glove-box?:confused:
  6. Craig K
    Craig K New Member
    17
    Connecticut
    Howdy all:
    I have used these for my iMac and they work great. I just ordered a set to use with the Autopilot stuff in side the armrest. It should make the space less cluttered with the cables. Just FYI.;).
    CableYoYo, Cable Yoyo, Cable Management
  7. BellBoy
    BellBoy Member
    223
    Simple...since I have the flex tube bent a certain way, it doesn't even come close to it.
  8. BerkshirePrius
    BerkshirePrius New Member
    121
    Berkshire, NY
    I use the Panavise mount along with the Dice cradle for my ipod. The dice kit does include a cradle for the iphone. (Sorry about the dirty interior, it's been way too cold to clean).
  9. keytohwy
    keytohwy New Member
    Martinez, CA
    Did you ever install this? I'm wondering if you couldn't use the mount that is pictured to the let of the MFD, but mount it to the right of the MFD and have the dock connector come through that vent.
    Anyone?
    keytohwy
  10. ad78
    ad78 New Member
    120
    Rocky Hill, CT
    edit: here's mine now. bought the metra mount @ CC for less than $3.00
    indicated for sequoia and tundra but it works perfectly on prius. no need to put screw. put hold tightly :)
  11. keytohwy
    keytohwy New Member
    Martinez, CA
    Wow! That's perfect. More pics? Part #?
    If you don't want to flood the boards, you are welcome to email me at keytohyw at gmail.
    Thanks!
  12. ad78
    ad78 New Member
    120
    Rocky Hill, CT
    sorry for the late reply.
    @ketytohwy - i'd rather post here :)
    ok, here how it goes....
    first, buy the bracketron on BB for iphone holder. cost $10.99
    here is the link
    Bracketron - Vent-Mounted Cradle for Apple® iPod™ and Mobile Devices - Black - IPM-202-BL
    i just did a little modification on this, i choose the ipod nano cradle but its a little bit of tight. by heating you can stretch the cradle.
    here is the metra mount on CC less than $3.00
    sorry blurry pics, taken on iphone
    and here some photos on the metra mount with bracketron
    im not worried about scratch because my iphone has invisible shield and it sticks right on the cradle :)
    by the way, im using this griffin autopilot.
    Buy the Griffin Technology AutoPilot and other iPod video accessories at circuitcity.com
    and with combo noise filter. to prevent unwanted noise.
    PAC SNI-1/3.5 Noise Filter Helps eliminate ground loop noise from your portable music player! (3.5mm plugs) at Crutchfield.com
  13. NashvillePrius
    NashvillePrius Junior Member
    TN
    Anyone have an update on this topic?
