Can I uplug my driver seat connector?
Discussion in 'Gen 2 Prius Technical Discussion' started by Thunderbolt, Feb 11, 2008.
  1. Thunderbolt
    Thunderbolt Junior Member
    Worthington Springs Fl.
    Will there be any airbag deployment etc. I want to explore the possibilities on moving it back a couple of inches.
  2. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    Disconnect your 12v battery if you do decide to unplug it. That's the closest I can come to actually answering your question. Sorry.
    EDIT: I believe others have moved the seats back a couple of inches. IIRC, there was a thread from the spring/summer of 2006 regarding this.
  3. Thunderbolt
    :) I assumed I could remove the 12v small battery, will have to reset window's, presets, etc. afterward. Just wanted to avoid that step.
  4. patsparks
    10,664
    569
    Adelaide South Australia
    If the ignition is off the airbag system isn't powered up.
  5. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Unplugging the connectors isn't hard, but adding two inches won't be so easy.
  6. KTPhil
    KTPhil Active Member
    1,379
    22
    There are medications for that now.
