How long do the "big" batteries last?
Discussion in 'Gen 2 Prius Main Forum' started by newbie, Feb 12, 2008.
  1. newbie
    newbie Junior Member
    24
    Maryland
    Someone told me the other day when I mentioned that I now have over 71K on my 2005 Prius that at around 125K I will have to buy a new battery (the big battery). I've never heard that before, have any of you? He said that the car was only built to last to about 125K.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    "Someone" is very poorly informed. No reason to think you should have any issues before 250K miles or more. The battery is designed to last the life of the vehicle.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    He might be referring to the batteries only being testing to around 100,000 miles. I'm sure someone will correct me on this one. But what I seem to remember is that the hybrid batteries were tested and put through cycles of charge and discharge to mimic about 100,000 miles of testing. After those tests, the batteries retained something like 95% "chargability" and the tests were suspended.
    But there have been 250,000 mile Prii already recorded on the original battery.
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i have heard it before and apparently will continue to hear it frequently in the future...
    obtw... it is total BS
  5. dipper
    dipper Senior Member
    1,242
    252
    Apparently it is false.
    But do remember there are the "ran out of fuel" threads, and now Toyota will void my battery warranty threads that go around too.
    So as long as the battery is treated without abuse, Toyota should not have a reason to void your battery warranty.... and it should last the life of the car.
  6. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    I have 120,000 on my '04. The batteries seem like new. If they go bad, it will likely only be a cell or two, not all of them.
    I have 50% of my front brake pads left, and 60% of my rear brake shoes. I changed my plugs at 120,000, even though they looked better than any of my old cars plugs at 30,000.
    I have never had to have any repair work done (except for when I hit a dog on the interstate). Replacing a couple of light bulbs, the air and cabin filters, a new set of tires, a couple of minor recalls, one set of spark plugs, one engine coolant change and the oil changes are the complete total of work done. Nothing has broken or gone wrong on this car.
    Don't believe the crud you hear. And good job coming here to get the truth. This site has the best information anywhere except for maybe talking to an actual Toyota mechanic.
  7. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    As I tell people who come up and ask at car-shows and the like,
    "the life of the car or better". Because of the 40-80% limits
    on SOC imposed by the battery computer and the hybrid ECU, wherein
    you can do as many "microcycles" as you want without getting into
    chemical cycle-life issues on the cells.
    A couple of Classics are apparently falling victim to a bad cell
    or two, but until he got smacked right near his hometown a couple
    of weeks ago, Jesse was yay close to 350K on his original battery
    and that's NOT a typo. Three hundred fifty thousand. Past the
    Vancouver taxi folks by a healthy margin.
    _H*
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    All I know is that my battery is warranted for 10 yrs / 150k miles under the CA AT-PZEV warranty. So if it needs replacement at 125k, I get a new one for free.
    I doubt that its going to happen that way.
  9. hill
    8,870
    heck ... I though the whole battery thing would be a good add to the 'troll' thread in FHOP .... something like, "I've heard the batteries die at such & such mileage, leaving you high & dry" ... there goes that idea :p
  10. dogfriend
    7,512
    1,190
    Carmichael, CA
    But I heard from a friend who's father knows someone who works for a company that sells stuff to Toyota that says the batteries won't last very long. :rolleyes:
  11. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    You forgot to mention how they are an environmental disaster too. Looks like you have to go back to Troll School :D
    Rob
  12. dogfriend
    7,512
    1,190
    Carmichael, CA
    Yeah, I usually spend my time refuting the trolls or ignoring them completely. I'm not a very good troll.
    BTW, on another board, I have had to refute the battery life argument and the environmental disaster argument. Because they heard it from someone or they read that ridiculous CNW marketing fabrication.
    People actually believe that crap, usually because they have no critical thinking skills.
  13. newbie
    24
    Maryland
    Wow! You all are the best. Thank all of you for your answers!!! I love this site!
  14. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i read an article a while back by Toyota that said they simulated 21 years of wear on the batteries before they were released into production.
  15. lys
    lys AerodynamicMac
    79
    SouthWest Europe
    For less fortunate warranties (8 years / 100k miles in my country) are a relief the CA policies.
    It gives us a "trust margin", even out of warranty.
    But at the end, if I still own the PRIUS in 8 years, I'll be thinking to go for a new and more efficient batt, probably "plug-in" and for a lot less money than now. Who knows.
  16. miscrms
    2,079
    526
    Phoenix, AZ
    Here is an interesting report done by the DOE on the Gen I Prius, as well as the insight and civic. At 160,000 miles they found the Prius battery had degraded quite a bit, but that the effect on mileage was very minimal. As I understand it, the batteries in the Gen II are even better than these. Keep in mind this is just one data point. Battery life will depend on many factors, including temperature, depth and frequency of cycling, etc. Toyota has done a very good job a trying to minimize these effects though.
    http://avt.inl.gov/pdf/hev/end_of_life_test_1.pdf
    Another data point, is the RAV4 EV. These had larger NimH batteries, but they were also cycled much more heavily and generally less protected (no gas engine to switch over to). The SoCal Edison test below show these still doing very well at 100,000 all electric miles. Many of these vehicles are still on the road 10 yrs later with their original packs.
    http://www.evchargernews.com/miscfiles/sce-rav4ev-100k.pdf
    Rob
