MFD failing? What's happening?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Blu_too, Feb 9, 2008.
  1. Blu_too
    Blu_too member
    At Evan's (efusco) suggestion, I am putting up my first post. Anyone experience similar problems? Is the MFD going bad? Evan's comments are included.
    I was waiting in my car with the ACC mode on so only the radio was on, display showed white, empty battery, and the clock was lit. The display began to blink and then turned black and the radio stopped. I powered off and waited then powered back on. The display message said something about parking on an uneven surface - it came & went so fast I couldn't read it fast enough to understand what it was saying. I tried to listen to the radio again in the ACC mode and the screen blinked and the radio sound went off and on then the black screen was back again.
    Since then when in ACC mode, either: A) the screen flickers and radio sound goes off and on and display comes on like it's booting up w/ the Prius logo then back to normal with the Energy Monitor screen, or B) the display attempts to boot up with the Prius logo flickering and the screen goes black.
    Observations: 1) symptoms begin about 2 minutes after putting car in ACC mode after each power off, 2) the ACC is still on after the screen goes black - I'm guessing since the screen is black and when I open the door to exit, the car is beeping and won't stop until I close the door and push the power button and I think the clock is still on. 3) no problems starting the car after powering off, 4) there are 4 or more blue battery bars showing, 5) the display is not dim like some of the other members have talked about, 6) message about parking on uneven surface only happened 2x
    Car factors: 2005 pkg #5, 36,600 miles, Platinum 7 yr/100K mile extended warranty from Troy before 36K miles, have no iPod or other add-ons. No problems when car is in IG ON mode. Haven't had a dead battery or run out of gas. Previously only used ACC mode for less than 15 minutes at a time, only 1-2x/week if that.
    Here is Evan's response:
    "That really does NOT sound typical of the MFD failures others have seen. And, if I'm reading your note correctly, you're saying the only time there's a problem is when you're in ACC mode? How about IG On mode? If you get similar behavior in IG ON my guess would be that your 12v battery is bad/dying and what you experienced was a draining of your 12v. Your car is a little young for that, but if you frequently listen to the radio in ACC mode for extended time you may have stressed it more than usual."
    Thanks for any help anyone can give before I talk to the Toyota service people.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Hey Blu,
    Congrats on your first post...hope it wasn't too painful for ya.
    What about the question I asked about what symptoms are seen in IgOn mode? Are they the same or different than ACC mode?
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Battery?
    When weird electrical things happen, it's easy to overlook the obvious: Is your 12V battery failing or does it have a loose connection? A 2005 could have an iffy battery, enough power to boot the computers and start using the main HV battery, but not enough to power the radio and display in ACC for very long. Have the battery checked as a starting point, and look here for many discussions of non-Toyota replacements which can save you a lot. Hobbit has done a lot of 12V battery research, among a vast amount of other things.
  4. Bill Merchant
    4,096
    81
    Battery?
    Oh, welcome to PriusChat, Blu.
  5. Bill Merchant
    4,096
    81
  6. richard schumacher
    7,663
    1,038
    United States
    The 12V battery is draining. The easy solution is to not leave the car in ACC or IG-ON. Leave it ON and in PARK, and let it take care of its own energy management as it was designed to do.
  7. Blu_too
    Blu_too member
    Thanks very much for the helpful responses. The First-post fears are gone!
    Evan, I will check on the IG-ON mode...how many times did I push the Power button and was the LED amber? Initially I thought there was no problem, but is it in ACC or IG-ON mode?
    And, I will take Bill's suggestion to have the battery checked today and post the findings. -Blu
  8. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    For the record -- the first symptom of the 12V system dropping
    too far when the car is on *is* that the MFD goes black. So
    there ya have it.
    _H*
  9. Blu_too
    Blu_too member
    It is looking more like the 12V battery that is the problem rather than the MFD failing.
    When on IG-ON, several times now, I've seen the message on the display in orange letters: "Caution - The transmission lock mechanism is abnormal. Park on a level surface and set parking brake" (or close to this) then the screen goes blank. I found a CNET article about this message and the author wrote that the battery was running low.
    Car virus rumors taken out for a spin | CNET News.com
    Sam's Club and my usual garage could not test the battery - I don't know why not. I did find a shop locally that has the Optima D51 YT ($189) in stock but they don't carry the installation kit. The Toyota battery is $198 at the dealer. Ground shipping is not an option here. Not many options.
    Now I know what I need to do - check for loose connection, get the battery tested, and no more listening to the radio on ACC mode. Thanks so much - you guys are *gooood*! :) -Blu
  10. Blu_too
    Blu_too member
    Hi again, Blu here,
    I got the battery tested -by an electrician - does that count?? It read 10V with the dome lights on. Now I need to go over to the 12V battery threads: can my battery be charged or do I need to buy a new one? Is this why my mileage has been slipping downwards? Moving on... -Blu
  11. drees
    drees Senior Member
    1,782
    247
    Yep, it's weak or failing.[/quote]
    With a good charger, it may be able to breath some life into the battery. Look into the battery tender. There is a lot of good info already in the battery threads.
    Quite possible.
  12. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    It's very unlikely (maybe impossible) that a failing 12V battery would have *any* effect on mileage. Once the car is running, the 12V battery is largely taken out of the equation; it's just a pass-through for the traction battery (i.e. big ~200V battery) powering things like the lights and the radio.
    I'm not sure where you live, but if you live in an area with cold winters, the mileage can really take a nosedive during cold weather. There are a bazillion threads on this phenomenon spread throughout the site.
  13. richard schumacher
    7,663
    1,038
    United States
    Except that the system will continually try to charge that failing 12V battery and thus waste energy. It could possibly have a noticeable effect on MPGs.
  14. Mr.Vanvandenburg
    1,039
    354
    2020 Prius Prime
    To check 12v battery voltage, very useful information was posted on these forums. On my model, "info" is pressed and held, and headlights are turned on and off three times. This brings up a screen. Menu is selected and then signal check(? don't remember exact term.) Then the battery voltage is displayed with other items. I have tried this several times and found my voltage to be 14.1 or 13.5 while driving. It seems to be 14.1 initially then went to 13.5. One test only. When parked unused for about a week I saw voltage of 12v before startup, quickly recovering to 14.1 when driving. The only thing I haven't figured out how to do is turn the screen off while driving. It seems to require a power off to cancel.
  15. Blu_too
    Blu_too member
    Hi All,
    I wanted to post the end of the story for my MFD turned battery problem.
    I got a new 12V Optima D51 YT battery, locally at a battery shop. They didn't have the installation kit and I didn't want to pay -$25 for the one from elearnaid.com ($15 + $10 s/h). Bill at Battery Bill's was intrigued with the Prius and fabricated his own adapter for me. I got a new battery ($189) and he gained experience in fabricating the adapter, removing the old battery and installing the new one. Thanks to the detailed installation instructions from PC members, everything went smoothly. Now other Prius owners around town have an option to replace with the dealer's battery ($200) or go with the Optima. Most everything costs more here in Hawaii, but that's the price we pay for living in paradise.;)
    The new battery made a difference with the display booting up more quickly. Mileage is still not good - I must be driving recklessly. The only glitch was right after the new battery went in, my auto-window button wouldn't work for up or down. This worked itself out quickly as Battery Bill thought it would.
    Thanks again to you all!
    -Blu
