Lowering Car to Improve MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Winston, Feb 15, 2008.
  1. Winston
    Winston Member
    614
    SF Bay Area, California
    So, there are springs availible now that will lower your car by 20mm. ( a little less than an inch). As noted by others, lowering your car will reduce your drag and thus improve mpg. Even GM has lowered their Tahoe Hybrid to improve mpg. Of course the only real improvement will be seen at highway speeds, but I wonder what the improvement will be? 5%, 10%? If I install the springs will I be able to travell at 65mph and get the same mpg that I got at 60mph? Any ideas on how to estimate the improvement?
  2. bwilson4web
    16,124
    I've been thinking about this for some time but had decided what I want are cabin controlled front bumper air-dam and side skirts. The idea is that at speeds above 45 mph, the air-dam and side skirts would descend to within inches of the road bed. Speeds above 45 mph tend to be on paved, relatively level and other than tires and road kill, fairly flat roads.
    Air dams and side skirts tends to force the air around the car instead of allowing it to 'stick' to the underside. It also generates a negative pressure to help hold the car to the road. Racers use serious air dams and side skirts for these effects and they should reduce the coefficient to drag to more than compensate for the larger profile area. But like all things in engineering, testing is the proof.
    GOOD LUCK!
  3. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Haha, Whats next? Perhaps we can then implement the F1-banned ground-effect to enable hypermiling those offramp 25mph corners at 55mph without hitting the brakes :p
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I think blocking the grill lower the drag more than lowering the car. I've scretch the lower front nose when I pull into some high parking curbs.
  5. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    As far as I know they are roughly equivalent. The drag force is proportional to the Coefficient of Drag (Cd) times the front cross-section area times the velocity squared. Dropping the car would decrease the area, smoothing air flow should decrease Cd, either is desirable. To the first order, you should be able to figure out the % decrease in front cross-section area to know how much improvement you might get. Ultimately the only way to find out is probably to try it :cool:
    Rob
  6. icarus
    icarus Senior Member
    4,884
    976
    earth
    I already can't drive in deep snow, or on the gravel logging road into where I live. I scrape the front valance parking, and getting on any ramp angles. If the car were any lower it'd be sitting on the pavement.
    Icarus
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Wouldn't lower your Prius then but some of us never drive on unsealed roads.
