initial mini review of new nokian WRg2 tires
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by konakahuna, Feb 12, 2008.
  1. konakahuna
    konakahuna Junior Member
    67
    knoxville, tn
    after 30K miles waiting for my OEM integrities to die, i did my research and decided to go with nokian WRg2 tires in the OEM size of 185/65/15. i've had the tires on for nearly a week now and wanted to pass along a few observations for those interested....
    1) the nokians definitely provide a more comfortable ride. this is most noticeable over rough sections of road where the rebound is more controlled and the jolt less jarring. i've never thought the prius was a particularly smooth riding car..despite its size, but these tires have definitely helped.
    2) the nokians have also sharpened up the handling. the steering effort is virtually the same, i suspect because the nokians weigh exactly the same as the integrities (17lbs. each), but they feel more precise and the car truly feels more planted and confident
    3) running the same pressure 40/38 as my old OEM tires, gas mileage has been a bit lower, but with only a hundred miles or so on them...they're not really broken in yet either. i have noticed a greater willingness of the prius to go into stealth and it seems to roll easier, which bodes well for my mileage down the road.
    so far, i've been very very pleased with these tires. i wanted better handling without paying a mileage penalty, and i think the nokians are going to deliver that for a reasonable price. no buyer's remorse here. more later as i get some wet weather experience with them...
  2. treehggr
    treehggr New Member
    230
    Thanks for the review. I'd be interested in hearing if your mpg improves over some time. May be my next choice in tires down the road.
  3. qbee42
    3,075
    How about tire noise?
  4. Pinan
    Pinan Member
    173
    Murrieta, CA
    Watch for an odometer slight over-read, as the tire's RPM is 849, while stock Integrities is 855.
  5. konakahuna
    67
    knoxville, tn
    tire noise seems very moderate to me, although i haven't taken my car much above 55mpg. i would say that at most speeds, the nokians are quieter than the integrities.
    also as for the difference in revolutions per mile, the diameter of the 185/65/15 tire is 24.5''. a difference of 6 revolutions per mile means a difference of 12.25 ft.
    there are 5280 ft. in a mile, so the tires will actually roll 5267.75ft. that's 99.7% of actual so at 60mph, you're actually traveling 59.82mph. a negligible difference.
  6. Pinan
    Pinan Member
    173
    Murrieta, CA
    I'm glad that I wrote "slight". Heh
  7. FishHawk
    FishHawk New Member
    176
    I am also interested itn this tire. Try running the tires at 42 /40 and see if the milage improves. FishHawk
  8. konakahuna
    67
    knoxville, tn
    i think my mileage so far has been due to several factors:
    1) sporadic cold weather that has lowered my total MPG
    2) new tires that haven't worn in yet
    given how easily my car seems to want to coast and go into stealth, i think the warmer weather combined with a few more miles on these tires will yeild MPGs as good as or better than the stock integrities.
    so far, i've been very pleased.
  9. FishHawk
    FishHawk New Member
    176
    That's good news. These will be my replacement tires when the stock tires ware out. FishHawk
  10. NoMoShocks
    1,292
    82
    Camas, WA
    I have had my Nokian-WR tires for a little over 5000 miles, and just recently pumped them up to 40/42 PSI. My mileage is back to 50 MPG, same as with the original tires, and I agree, the Nokian tires are Great! Mine ore the older version, not G2
  11. prim2
    prim2 Junior Member
    64
    Toronto
    "also as for the difference in revolutions per mile, the diameter of the 185/65/15 tire is 24.5''. a difference of 6 revolutions per mile means a difference of 12.25 ft.
    there are 5280 ft. in a mile, so the tires will actually roll 5267.75ft. that's 99.7% of actual so at 60mph, you're actually traveling 59.82mph. a negligible difference."
    If I recall geometry correctly, you need to multiply the diameter by Pi, or 3.14159 to get the circumference. So, six revs would transport you 38.5 feet. (Still fairly minor).
  12. konakahuna
    67
    knoxville, tn
    you are totally correct. i have always SUCKED at math.
    let's try this again.
    24.5'' diameter x 3.14 = 76.93'' circumference x 6 additional RPM = 461.58'' or 38.465 ft.
    the nokian tire will roll 5241.53ft. instead of 5280ft. so that yields 99.27% of the total......so if i haven't screwed up again,
    at 60mph, the nokians will actually be going 59.57mph
  13. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    so you very happy with the tire? for us prius owners how long you expect that tire to last until you have to replace it again? if it can get 3 winters out of them then that'll be pretty good!
  14. craigk
    craigk Member
    139
    Golden Valley, MN
    I purchased my WRG2's this spring, have 3300 miles on them and the treadwear indicator is already missing the 8 (4-6-8). Perfectly even wear, alignment was checked at installation. Car handles great, summer mpg's are easily in the +/-50 range, but don't know why they are wearing so quickly?
  15. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    Because they're a soft compound designed to work in very low temperatures. The WR is a winter tyre, not all-season. In summer the compound gets too hot and wears quickly.
    Nokian make summer tyres as well. I'm going to try out some 'H' tyres (seriously, that's what they're called, simply after their speed rating) because after 21,000 miles, the OE Bridgestone Turanza ER30s (UK model) are worn out - down to 3mm tread on the front. I would try the i3, which have had good reports from US owners, but Nokian don't make them in 195/55 R16. (They're good for the 185/65 R15 size used by the 'base', non-Touring Prius.) The i3 is T-rated (up to 118mph) and are plenty for the Prius.
    Nokian are working on ultra-low rolling resistance tyres: Nokian Tyres - Summer tyres - Winter tyres - Friction tyres - Studded tyres
  16. craigk
    craigk Member
    139
    Golden Valley, MN
    Nokian WRG2 Update-
    I have only 17,100 miles on my WRG2's, still handle great but wear indicator is down to 4 and under (8-6-4) already. My Nokian Hakkapeliittas, a soft tire for winter have 13,000 plus miles and still have 6 on the indicator, seem to be wearing just as well or better...I figured the WRG2's would go longer, will look for less soft tire for summer next time.
    (just put on my Hakkapeliittas for the first snow of the year and it's like I have all wheel drive! All I need is a lift kit and I could go through anything:D)
  17. F8L
    19,011
    4,081
    Grass Valley, CA.
    Craig, if you like the Nokians and want to stick with them then look into the enTYRE or i3. Both are great tires. I've ran the i 3 and really liked them. For the money there may be better options with longer treadwear.
