Hill Climb and Descent Control 2008 ?
Discussion in 'Gen 2 Prius Main Forum' started by SyCo, Feb 20, 2008.
  1. SyCo
    SyCo Member
    207
    17
    Quebec
    One of my relative is interested in buying a new 2008 Prius...yeah !! :D
    I was looking at Toyota.ca website to see all the features of the new 2008 model.
    One thing I saw was:
    Now my question is... Is this available on all models from 2004 to 2008? Or do you need to have VSC ? Or simply the TRAC ?
    I did a search on "hill descent control" but found nothing here on PC.
    p.s. Also it maybe a bit off topic but what is the best way to know what package I have on my 2005 Prius ? Is there a VIN decode I can do ?
    thanks ;)
  2. Tideland Prius
    16,681
    They're throwing the words around incorrectly.
    The way they word it, you'd think they have hill-start assist and downhill assist control (DAC).
    The Prius has neither. All they're saying is that there is a creep incorporated into the HSD system so that the car will hold on a slight hill (like a regular automatic car) and not roll backwards like a manual car.
    Hill climb is just the CVT adjusting when you approach the hill, similar to "Grade Logic" regular automatic transmission.
  3. SyCo
    SyCo Member
    207
    17
    Quebec
    ok thank you
    Yes in D the car goes forward a bit if I don't touch gas or break. If I press the break lightly the car wants to go forward (I see energy flow on the MFD) but if I press harder then no more flow.
    For "Hill Descent Control" I use B
    :D LoL
  4. Tideland Prius
    16,681
    lol.
    What's annoying (good and bad) is that when the battery is full (or doesn't want to take any more charge), the engine starts to rev up even in D (supposedly so I don't overcook my brakes).
    The problem is, that there's a sign that says (Quiet please! Don't use engine braking etc etc). I can't help it cause the car does that in D! If I want to lower the engine rpms, I'd have to accelerate down the hill!
    Oye haha. "But officer, I was in D not B!"
  5. tkil
    tkil New Member
    158
    Don't know how tongue-in-cheek that was, but the "engine brake prohibited" signs are most often talking about the proper compression brakes ("jake brakes") on large semi-trailer tractors. (And on the Dodge pickup trucks with the Cummins diesels, I guess.) Those engines have a special cam setting which opens the exhaust port at the top of the compression cycle; since the wheels push back through the transmission to compress the air in the cylinders, that allows for true compression braking.
    Normal gas motors are actually vacuum braking more than anything else: the compression isn't let out, so it just expands again. do not know whether the Atkinson cycle changes that at all.
    See also: Jake brake - Wikipedia, the free encyclopedia
  6. Tideland Prius
    16,681
    I'm serious. Haven't you seen those signs? It's has a truck and all that.
    I mean when we engine brake, it's a similar idea and still produces more noise than in D (or in a higher gear).
    The Prius does that automatically in D when the battery's full. If I have the radio off, it's fairly noisy (I'd wager 2,500-3,000rpm). Shift to B at that point and man will you be in for a surprise (I'll wager 4,400-5,000rpm). You'll think the engine will blow itself up.
  7. tkil
    tkil New Member
    158
    Heh. The ones here (SW USA, mostly NM and AZ) are text-only, although the text varies: "engine brake prohibited", "engine brake muffler required", "jake brake use prohibited", etc.
    You're right that the Prius ICE can sound dangerous at high RPMs, but the Wikipedia article accurately describes unmuffled Jake Brakes as sounding like a "machine gun". If nothing else, you've 4-5x the volume getting compressed and discharged (relatively instantly, from a high- (diesel-level!) compression), vs. the relatively gentle exhaust pressure level on the Prius.
    (And I've been doing a fair bit of climbing at 75 mph lately, so I know what a screaming ICE sounds like!)
    Seriously, you're not going to get pulled over for that particular infraction... thus my asking whether you were joking or not. If you do get pulled over, your "it was in 'D' not 'B' officer!" defense is actually a completely technically correct and valid one; large diesels traditionally have a separate control for whether the engine brake is active, and if you are not deliberately engaging the engine brake. then you should not be found in violation of the ordinance. (Whether they need to then rephrase their signs as "Prii not welcome" is another story.)
  8. patsparks
    10,664
    569
    Adelaide South Australia
    The "engine braking" you are talking about is almost silent from outside the car. The reason there is a picture of a truck on the sign is because it applies to trucks.
    There is a massive difference between the noise of a Prius spinning the ICE against compression and a GM or Cummins diesel barking through a sports muffler or no muffler with the jake brake opperating and a cowboy at the wheel.
  9. arntz
    arntz Junior Member
    Australia
    i-Tech
    For those that don't understand the braking method of the Prius, it is very similar to that used on electric trains.
    During normal braking, instead of the brakes applying and turning the car's momentum into burned out brake pads and heat, the Prius turns that energy into electricity. To protect the batteries when they become close to fully charged, that energy is partially sent to the motor/generator attached to the ICE, which causes the engine to rev up, and uses engine compression and friction to retard the vehicle speed. That is commonly referred to as Dynamic Braking. When the speed reduces to around 5 KM/H, the electric motor no longer runs fast enough to produce electricity, so the normal brakes blend in automatically to compensate for the loss of braking effort. When you place the gear lever into the 'brake' zone, you are using Dynamic Braking. It is inefficient, DON'T USE IT, unless you are going down very long steep grades.
    With electric trains, electrical energy is forced into the overhead wires for use elsewhere within the network during braking. If for some reason the overhead wire can't take it, the train automatically diverts that electrical energy to resistor grids located on the train, and converts it into heat.
    imOCD4a_prius likes this.
  10. qbee42
    3,081
    A point of clarification relating to the above post: Braking though the electric motors is called dynamic braking. When the generated electricity is saved for later use, it is usually called regenerative braking, although it is still a form of dynamic braking. The Prius does dynamic braking automatically; you don't have to do anything special to use it. The recovered electricity is stored in the HV battery until it reaches a high limit, then the excess is used to spin the ICE as an energy waster. Friction brakes are employed if the dynamic braking is insufficient, or at speeds lower than eight mph. Using B mode on the shifter tells the Prius to immediately start wasting energy by spinning the ICE. There are also some minor modifications to the regeneration curve, but otherwise the braking in B mode is the same, with the same shift to friction brakes as needed.
  11. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    From my tests, the Prius actually has a "hill holder", it's just electronic. When in "D" or "B" the HSD will not allow the car to roll backwards (unless you overpower it). It -can- move a bit due to play in the gears.
    I had a Subaru and its' "hill holder" was a ball bearing in the brake circuit which held the brakes until you released the clutch. The ball bearing was a "gravity detector", to tell when the car was stopped on an uphill.
    As far as their claim of downhill control, it's probably "B" they are talking of. It uses engine compression to dump energy, and thus "control" the downhill coast.
  12. Tideland Prius
    16,681
    Yeah I know what you mean. The trucks here do it all the time in the city to save their brake pads.
    There must be no mountains near Adelaide. Try going down the mountain side at 70km/h and shift to B. It sounds like a small twin engine plane coming in for landing. ;)
    Yeah but a hill holder would be one that holds the brakes for a second or less to let you switch from the brake pedal to the accelerator (e.g. 03+ 4Runner).
