What do you use for keeping track of your maintenance?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SLO Cat Wrangler, Feb 22, 2008.
  1. SLO Cat Wrangler
    SLO Cat Wrangler Junior Member
    96
    San Luis Obispo, CA
    What are people using to keep track of their routine maintenance, tire checks, other important events in your car's life? Do you use a note book with special pages? A Computer application? Online application?
    Thanks,
    Steve
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I use the maintenance passport that came with the Prius. It has all the details of what service is needed, and when and a place to record the mileage and date when you did it. what more could you need?
    :confused:
  3. bwilson4web
    16,202
    Post on USENET?
  4. SLO Cat Wrangler
    96
    San Luis Obispo, CA
    Hey thanks for the quick responses!
    I like the prius log that comes with the car, but there isn't enough room for things and comments that I like to write like, checked tire pressure, washed car, vacuumed car, found scratch on side of driver door, filled with gas, etc.
    I am thinking of going electronic (maybe excel spread sheet, word doc, or something online), however am not sure that what I create today will be here 10 years from now. I also want to have access to it when I am traveling and I don't have a reliable electronic connection (laptop, cell phone, other wireless device to get to the internet) so I am still thinking about pen and paper solutions. I have tried 8 1/2" x 11" ring binders for my cars in the past, and while these are nice because there is a lot of area to write in, they are also really big and bulky. A half side book would be better or maybe I should make a page in Word and have Kinko's bind them into a small book.
    Hey Bob, I'm not familiar with Usenet. What is this and where can I find out about it?
    Thanks,
    Steve
  5. Rest
    Rest Active Member
    1,210
    CA
    Pad of paper here.
  6. Godiva
    Godiva AmeriKan Citizen
    10,339
    The odometer and the owner's manual.
  7. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    I use excel. Keep a print of current tanks in car with a grid to record new tanks and other notes on maintenance.
    I set up the scheduled maintenance items with time/mileage intervals. Then when I enter odometer reading in excel, it takes that and the system date and shows how long until <past> the recommended intervals for both miles and time.
    Otherwise, I won't remember all the items.
    PITA to set up the first car, but it works for me.
  8. Tripod137
    Tripod137 New Member
    145
    Long Island
    KarKare for the Palm.
  9. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    How about the Maintenance feature of the MFD Info page. It will trigger a visual reminder of most every concievable maintenace item and a couple custom ones too.
  10. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    I use a couple of simple spreadsheets. One for maintenance and one for gas purchases and mileage. I have attached each of them in PDF form. I have used these forms for several years and they do what I need to do.
  11. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Me too. A little spiral bound pad that I keep in the center console. I use it as a "Chron File" for my Prius -- a running record of my gas fill-ups, milege, modifications and maintenance.
    Pen and paper. It works.
  12. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    I'm using a spreadsheet.
    Right now I'm trying to figure out why my calculated mileage based on miles driven divided by tank refill gallons is so different than the mileage given by the Prius itself.
    Prius says 52.1mpg, but my miles/tank calculation says 44mpg. [​IMG]
  13. hill
    8,800
    That's what we use ... coupled with the shoe box full of dated receipts.
  14. SLO Cat Wrangler
    96
    San Luis Obispo, CA
    Thanks again,
    On my info screen I only see travel info, language, and selections. Where is the maintenance feature? We have an '08 package #2
    Steve
  15. kocho
    kocho Member
    134
    Maryland
    I looked at your maintenance log - how do you actually balance the tires yourself? Do you have a machine?
  16. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    The maintenance screens are included with the Navigation system.
  17. aaf709
    3,862
    2022 Prius Prime
    I use a Vehicle Maintenance logbook which I get at Office Depot.
  18. SLO Cat Wrangler
    96
    San Luis Obispo, CA
    I see. So If I don't have the navigation system then I guess I don't have those maintenance screens either right?
    Steve
  19. okiebutnotfrommuskogee
    1,813
    Tulsa, OK
    Cars have been our family's hobby for years. We actually have a computer balancing machine like the one in the tire stores. Put the wheel on, enter info. (wheel width, wheel diameter, position and type of weights), lower the hood. The machine spins the wheel then tells you how much and where to place the weights. We also have a state of the art tire mounting machine to go along with the balancer.:)
  20. kocho
    kocho Member
    134
    Maryland
    Ahhh! That explains it :) I had wanted on more than one occasion to go out and buy one of these after repeated unsuccessful balancing acts by various tire install establishments... But then I'd need a bigger garage too.
